Quick questions for the new Hyper - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Aug 10th, 2008, 9:49 am   #1 (permalink)
Treadmarks's Avatar
Just bought a new S on Friday. She runs great but I'm getting the mod fever.
Post buy inspection revealed the loose battery ground cable and loose battery hold down bracket. Also did the throttle cables and suspension setup. All went well thanks to the data here on the forum. Thanks!
I saw mention while searching of a walkthrough on the airbox mod, but I couldn't find the actual thread with pics. I ride in the rain quite often and don't want water in the airbox to be an issue. Could someone please point me in the right direction?
I keep reading about evap cannister removal and will probably do this today. Do I need to keep everything available to reinstall just incase it has to go back to the dealer? Will I void the warranty by removing it?
Is there a mod to the factory cat or pipes to make it a little louder? Will degutting the factory cat require the DP ECM or is there a way to make it a little louder without needing an ECM.
Thanks in advance for any and all help.
This bike and this forum rocks!
TREADMARKS
Ford F150 4x2 Lifted
Treadmarks is offline   Reply With Quote
Old Aug 10th, 2008, 3:13 pm   #2 (permalink)
Monstaman's Avatar
Cat post I can help with..
gutting the cat convertor??
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Aug 10th, 2008, 5:16 pm   #3 (permalink)
Treadmarks's Avatar
Thanks for the quick reply Monstaman.
I did the evap removal today. Pulled the barbs and used very short 5mm socket head capscrews with the factory crush washer and a drop of loctite. Aslo removed the frame stickers and installed a silverstar 60/55 headlight bulb.
TREADMARKS
New Hyper Owner Questions Rozebud HyperMotard 1 Mar 10th, 2008 10:06 pm
Quick chain replacement questions blappo Supersport 2 Jan 26th, 2008 8:25 am
Hi I have a quick set of questions before I purchase my first ducati! cmc12345678910 Superbikes 24 Jun 16th, 2007 11:59 am
Quick Hello...and a few questions... LA-DUC Sport Classic 7 May 31st, 2007 2:02 am
fuel quick connects and spark plug questions! =) dragknt Superbikes 4 Oct 31st, 2006 9:20 pm
