Suspension is the best thing you can do to immediately make this bike better than you thought it could be. Make sure to set your sag before you do anything with the compression and rebound settings.
The general consensus is that this bike is set up for riders between 180-210 lbs as for the springs and guts. However, it appears that the biggest complaint is that you can never get the high speed compression setting just right. Ghezzi has changed his fork oil to a lower weight and seems to have cured that problem with the front. I think he is about to do the rear too.
I have my bike setup pretty good and I will probably end up doing the fork oil too. Then maybe do something with the rear, but mine seems to be pretty good for my riding style.
Do a search on suspension and you will get a few threads with some sag, compression, and rebound settings as a starting point.
Here are mine. Just setting the sag with eliminate the front end twitchiness.
Suspension Settings
Out!
