Quick TPS Question - Ducati.ms - The Ultimate Ducati Forum
Old Aug 7th, 2008, 10:53 pm   #1 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
Quick TPS Question
If I adjust throttle freeplay per the Owner's Manual, will I have to have my TPS reset?
Thanks.
-Marco
Da_Bull is offline   Reply With Quote
Old Aug 7th, 2008, 11:07 pm   #2 (permalink)
No (at least on mine I didn't)
corynord1 is offline   Reply With Quote
Old Aug 7th, 2008, 11:17 pm   #3 (permalink)
Da_Bull's Avatar
Word. Thanks.
-Marco
Old Aug 7th, 2008, 11:40 pm   #4 (permalink)
Monstaman's Avatar
Thanks.
Yes you will, you will also need the full headers, cams, DP ECU PC111, High compression pistons and new muffler bearings.
No TPS involved with what you are doing you are fine!
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Aug 7th, 2008, 11:50 pm   #5 (permalink)
Da_Bull's Avatar
I haven't installed muffler bearings in a while; hope I remember the process.
I did go out and get a can of Compression Powder to hold me over until I do the full exhaust, though.
Since we're talking full exhaust, I might as well ask ... when switching to the DP "Full Race" ECU, do I need to use the O2 sensor or just plug the 02 bung?
-Marco
Old Aug 7th, 2008, 11:55 pm   #6 (permalink)
Monstaman's Avatar
You can just leave it as is as the ECU disables it anyway, or you can choose to remove and plug the hole and tie up the sensor wire.
Also be sure you have the correct compression powder as the heavier grade can cause detonation
Cheers KTiMpostor
Monstaman
Old Aug 7th, 2008, 11:58 pm   #7 (permalink)
Da_Bull's Avatar
Good call on both. I'll check what grade powder I've got. I should be good on PINGing, though, as I've got 100 octane at a local pump.
Thanks for the insight.
-Marco
Old Aug 8th, 2008, 11:54 am   #8 (permalink)
Banned
Okay being new to Duc's - do I have to run the DP blinker fluid or will high quality aftermarket like RedLine work?
Old Aug 8th, 2008, 12:06 pm   #9 (permalink)
Da_Bull's Avatar
You'll pay more for the DP blinker juice because it says Ducati on the box. Any aftermarket, high-grade fluid will suffice.
-Marco
Old Aug 8th, 2008, 4:06 pm   #10 (permalink)
Lumpy Idol's Avatar
Images: 21
A guy at the dealer told me to change the coolant out at the first service.
Also mentioned something about a billet waterpump?
Lumpy Idol is offline   Reply With Quote
quick exhaust question... quackattack Superbikes 0 Jan 16th, 2008 12:46 pm
Quick 998 Question cmc12345678910 Superbikes 10 Aug 29th, 2007 2:36 am
916/996/998/748 fuel quick disconnects question level7 Superbikes 10 Aug 21st, 2007 8:57 pm
Quick Ohlins shock fitting question tye1138 Superbikes 3 May 11th, 2007 1:02 am
Quick question, Rotor offset DukeDesmo Superbikes 16 Mar 9th, 2007 12:11 pm
