Chain Adjustment - Ducati.ms - The Ultimate Ducati Forum
Old Aug 7th, 2008, 10:52 am   #1 (permalink)
Chain Adjustment
Trying to figure out how to adjust the chain. I just ordered a rear axel slider kit so I can use my pitbull swing arm stand. Not sure what to do from there. I read the manual but the directions were not great.
93Octane is offline   Reply With Quote
Old Aug 7th, 2008, 11:05 am   #2 (permalink)
jediduc's Avatar
Here you go from the shop manual...
Hope this helps...
'10 Streetfighter S
'08 Hypermotard S
a man's got to know his limitations.
jediduc is offline   Reply With Quote
Old Aug 7th, 2008, 11:29 am   #3 (permalink)
just need to do it on the side-stand. 30mm-33mm from the metal swingarm to the chain center. loosen 2 - 14mm pinch bolts & rotate the chainguard back until you get the proper tension. IIRC, the pinch bolt TQ is 31nm
Is the info on the chain tension label correct?
Old Aug 7th, 2008, 12:56 pm   #4 (permalink)
any videos on this?
Old Aug 7th, 2008, 1:21 pm   #5 (permalink)
video on adjusting the chain? not much to it.
push up in the chain & release.
measure.
if you need to tighten the chain, undo the 14mm bolts and rotate the rear chain guard to the rear (clockwise) to tighten the chain.
Chain Cleaning, Waxing and WD-40 Shazaam Hall of Wisdom 41 May 9th, 2012 4:11 pm
Chain Inspection and Freeplay Adjustment Shazaam Hall of Wisdom 1 Jan 10th, 2012 11:41 am
748 Chain Adjustment HELP BIG RIDE TOMORROW pbtakacs Superbikes 22 Jul 31st, 2008 12:56 am
999s Gearing Change Soarer Superbikes 8 Jul 18th, 2007 10:45 am
