Aug 7th, 2008, 8:19 am
1st Service
I have about 1200 miles on my hyper s. I didnt do the 1st service because my dealer is busy(which is good). To the people that have had a 1st service, what is done? I was told not to exceed 1500 miles if possible. Any help would be great.
Aug 7th, 2008, 8:21 am
oil change, check belts, fluids, chain, bolts, brakes, etc...
Aug 7th, 2008, 12:49 pm
I am in the exact spot as you. The only thing that is important is to change that oil ASAP! It still has all the break-in metals.
if you need to know... ask...
Aug 7th, 2008, 1:00 pm
is it safe to go to synthetic after the first service?
Generally its better to wait until the engine wears a little before switching to synth.
Aug 8th, 2008, 6:45 am
Synthetic, all the way
I had the dealer (Wagner) do the first service while they were centering the TPS and syncing the throttle bodies (I added the full Termi 2 into 1). The service tech told me that Ducatis come from the factory with synthetic oil and that synthetic is what Ducati recommends.
I had to bend over for 4 liters of $16/l Motorex 15w-50...
Get that oil out of there ASAP, it was installed at the factory, last year, when your ride was liberated from Italy!!
RS
Only Rich People Can Afford Poor Quality
Aug 8th, 2008, 10:10 am
If you're going to do the oil change, make sure that you check the screen...could be some metal bits in there the first change or two.
Aug 8th, 2008, 11:23 am
where is the screen?
Aug 8th, 2008, 12:47 pm
a little below the clutch cover area. it's covered with a 14mm (?) hex.
you'll probably have to loosen/remove the horizontal pipe to get it out.
Aug 8th, 2008, 1:16 pm
Try this Oil Change
Use recent version of Internet Explorer.
Aug 8th, 2008, 3:52 pm
Originally Posted by georound
Try this Oil Change
Thanks for the Oil Change "how too". Btw will changing my own oil void my warranty?
2008 HM S
- Termignoni 2-2 Rear Section - Zard Full Midpipe - DP Race Seat - Motovation Frame/Fork Sliders - Pazzo Shorty Brake/Clutch Levers - Tidy Tail -Speedy Moto Clutch Cover and Pressure Plate - Piaa GTX H4 Headlight
03 Dodge Ram QC Hemi
99 Dodge Viper GTS ACR
