Broke the clutch actuator pin - Ducati.ms - The Ultimate Ducati Forum
Old Aug 5th, 2008, 11:14 am   #1 (permalink)
georound's Avatar
Well, I was monkeying around and decided to put a CRG clutch lever from a 1098 onto my hyper last night. Since you have to reuse the pin and it seems to be locktited with the red stuff, it broke. Fortunately, I was able to salvage the pin with one thread and use the barrel that came with the lever.
However, it's pretty hard to shift now as it's not fully engaging the clutch.
Ducati doesn't sell the pin seperately.
Anyone have this laying around with/without a stock lever? PM or post if you have a suggestion, including someone that could machine one.
Thanks
Old Aug 5th, 2008, 12:14 pm   #2 (permalink)
which pin? the pivot bushing?
Old Aug 5th, 2008, 12:59 pm   #3 (permalink)
georound's Avatar
I found a picture that shows that pin. This lever is from a 749/999 and looks like its the same thing. I found an aftermarket lever at 58cycle for 18 bucks plus shipping.
Old Aug 5th, 2008, 1:15 pm   #4 (permalink)
ah...with the Pazzo's, you tap out the pivot bushing to remove (and reuse) that whole piece.
good luck with the search.
Old Aug 5th, 2008, 2:01 pm   #5 (permalink)
georound's Avatar
In hindsight, I should have used the barrell and pin as a whole, but the oem barrell was a bit sloppy in the crc hole.
Ducati and After-market Clutch Master and Slave Cylinders Shazaam Hall of Wisdom 16 Dec 12th, 2011 4:30 am
New Clutch, Decisions, Decisions ... Shazaam Hall of Wisdom 6 May 19th, 2011 9:00 am
EVR Slipper Clutch - MUST SEE!!!!!!!!!!!! wrichards Superbikes 20 Nov 20th, 2007 10:46 am
need help guys (clutch basket) ThePharaoh Ducati Motorcycle Chat 10 Jul 21st, 2007 5:47 pm
But another clutch problem, I broke it! Tryful Superbikes 6 Jun 21st, 2006 1:30 pm
