WBO2, CO% and idle - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jul 30th, 2008, 2:09 pm   #1 (permalink)
WBO2, CO% and idle
new to working on morotcycles, but familiar with tuning cars.
All the posts i've seen setting CO% & Idle use a CO gas tester. can you do the same thing with a Wide Band O2 (WBO2)? if so what values should i shoot for?
Old Jul 30th, 2008, 3:43 pm   #2 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
If you can measure A/F at idle/no load with your WBO2, 12.7 to 1 should get you in the neighborhood of 5% CO.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Jul 30th, 2008, 3:51 pm   #3 (permalink)
Thanks!!
Old Jul 30th, 2008, 4:59 pm   #4 (permalink)
GMP
Taking it one step more, has anyone tried one of these?
http://www.wbo2.com/2j/default.htm
Looks like you can program the narrow band lambda signal for any reasonable AFR you want. This might work good with a stock ECU, as long as the trim limits are wide enough to accomadate the selected AFR.
Interesting device.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Jul 30th, 2008, 5:54 pm   #5 (permalink)
that product uses the Bosch WBo2 sensor, which is a common WBo2 sensor. the Bosch WBo2 sensor is also used by VW. i know this because i killed one of my sensors and went to VW for a quick replacement.
the narrow band (simulation). will allow you to fool the ECU when it's in closed loop operation. if you have a DP ECU, no need for the NBo2.
for the price, you can get the LC-1 from Innovate.
Old Jul 30th, 2008, 9:41 pm   #6 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
The Innovate is supposed to be one of the best, but their support seems questionable. I attempted to purchase one awhile back but they did not get back to me. I think the cost was in the neighborhood of $600. You would have to read off of both cylinders individually to check A/F ratios, then you would need a means of adjusting the fuel map for each cylinder (with a PC or Rapidbike module). It gets real expensive very quickly!
In the end, I started with a Rapidbike 3 module and base fuel map that was supposed to be close to my bike's configuration, then went about tweaking the map the same way I would jet a carburated bike. Got it very close and validated the A/F on a dyno and made some more tweaks after that. Pretty happy with the way it runs, pulls cleanly and throttle response is great with no surging or bogging.
-2008 Hypermotard S
-2005 Buell XB9SX
-2005 CRF170R
Old Jul 30th, 2008, 10:02 pm   #7 (permalink)
tell me about it, but in the end it's worth it.
my Subaru WRX put down ~140whp stock, and now it puts down 330whp, BUT it took some $$$ to get there.
now if we could just get Desmosedici power out of the Hyper
higher idle after running ... johnchypermotard HyperMotard 26 Aug 4th, 2008 1:37 pm
SAC's Guide to Idle Adjustment- Now With Pictures! SAC Superbikes 15 Jul 24th, 2008 3:30 pm
Idle troubles with my 2007 GT ducatied Sport Classic 2 Nov 12th, 2007 10:26 pm
Power Commander Idle Question luther_r Sport Classic 5 Sep 30th, 2007 2:45 pm
What's with the Idle Speed? LiquidSilver Ducati Motorcycle Chat 16 Jun 9th, 2006 1:58 pm
