Question for the wizards- ECU - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jul 27th, 2008, 9:31 pm   #1 (permalink)
Does the slipon ecu keep the exhaust valve open??? Thanks in advance!
MDMason is offline   Reply With Quote
Old Jul 27th, 2008, 11:50 pm   #2 (permalink)
yes, mine makes no noise now when i turn on the key
Old Jul 28th, 2008, 6:41 am   #3 (permalink)
there is also no "EXVL" parameter in the hidden menu.
Old Jul 28th, 2008, 2:48 pm   #4 (permalink)
Home of vortex tuning
CDONA's Avatar
If you unplugged the servo motor will you get the "engine light" on the dash?
Old Jul 28th, 2008, 4:20 pm   #5 (permalink)
Thanks guys, Hopefully it's open!
Old Jul 28th, 2008, 8:33 pm   #6 (permalink)
GMP
With the stock ECU yes, and also if you just disconnect the cables, although this is less consistant. You have to prevent the motor from going overtravel and setting a code. I made a plate with stops and 6mm pins in the pully where the cable anchors were.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Jul 30th, 2008, 3:14 pm   #7 (permalink)
CDONA's Avatar
I disconnected the closer cable only and got the engine light with stock ECU. The question was for the slipon ECU. As I understand it, the flapper still is in the system but not actuated, and a open loop, (no o2 sensor)? If unplugged will the light come on?
Old Jul 30th, 2008, 4:30 pm   #8 (permalink)
I am using the SOecu with the leo cat pipe and get no light.
Scotty
08 hypermotard S
08YZF250F SM
06WR450F SM
scottysspeedshop is offline   Reply With Quote
Old Sep 25th, 2008, 8:15 pm   #9 (permalink)
Monstaman's Avatar
I dug this old thread up while looking for answers, I have the DP ECU and it appears that the flapper valve can be completely disabled and disconnected from the loom, I have done over 250 km with 8 - 10 start ups over 5 days and get no error engine light.
When I turn the bike on there is no motion in the stepper motor and at 3750 when it is supposed to be activating it still does nothing so I simply disconnected it from the loom to see what would happen and nothing happened at all.
My o2 sensor is removed and disconnected from the loom as well.
So, I am going to remove the motor and cables complete and I am now waiting for my new Zard header set to arrive from Anthony @ Desmo.
Interesting stuff really, cheers all.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Sep 25th, 2008, 8:31 pm   #10 (permalink)
georound's Avatar
Funny that you dug this up. I have the DP slipon ecu but it moves the flapper and occassionally, I get the exvl 13.1 error message. So, maybe I can unplug the valve with no error?!?
DP ECU question Smiley_69 Sport Classic 3 Jul 11th, 2008 5:14 pm
2001 SS900ie - Exhaust + ECU question DucFanDan Supersport 9 May 7th, 2008 10:07 am
FIM ECU question DucFanDan Monster 0 Apr 30th, 2008 11:48 am
FIM ECU question DucFanDan Supersport 0 Apr 30th, 2008 11:41 am
DP Slip Ons & ECU Question Mac900 HyperMotard 5 Mar 18th, 2008 2:59 am
