Got Cams, will need ECU. - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jul 26th, 2008, 6:37 pm   #1 (permalink)
Senior Moment
Buckelew's Avatar
I purchased some Ducati Performace cams. I figured I'd look for the proper ECU for it.
Can someone tell me what the number is? And anyone got one for sale?
Buckelew is offline   Reply With Quote
Old Jul 27th, 2008, 10:02 am   #2 (permalink)
GMP
Buckelew,
I think this is what you need:
http://www.ducati.ms/forums/showthre...ighlight=hyper
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Jul 27th, 2008, 10:42 am   #3 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Part number for the ECU that comes with the cam kit is 96519208B. An alternative to getting this ECU is a Rapidbike O2 Emulator and Rapidbike 3 module. You can dial in your fueling and ignition advance curve using the stock ECU. Cost will be close to $800 plus dyno time. Factory Pro (Wheelsmith) in San Rafael can do the tuning. I also have some base fuel/ignition maps I can give you as a starting point if you go this route.
If you get the DP ECU, you will probably still need to get at least a Power Commander to optimize your fuel map as this ECU is a little rich on the bottom and top end.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
DP ECU for Hypermotard interchangable with Sport Classic? garth Sport Classic 7 Jan 12th, 2009 7:13 pm
WTB: Hypermotard Cams and ECU parkcrf HyperMotard 5 Jun 23rd, 2008 1:09 pm
15M ecu - help! dirkwrong Ducati Motorcycle Chat 7 Mar 28th, 2008 7:46 am
powercommander, rapidbike, techlusion, DP ECU, or ultimap? stlouisrider Sport Classic 5 Mar 14th, 2008 9:36 pm
DP race cams yota HyperMotard 36 Dec 1st, 2007 3:16 pm
