Coring stock mufflers? - Ducati.ms - The Ultimate Ducati Forum
Old Jul 24th, 2008, 7:42 pm   #1 (permalink)
Has anyone tried this yet on their bike? I know the SS, Monster and SBK guys have done it with good results in improved sound quality. I'm sure the process is similiar. I just can't take the weak sound of the stock cans.
SP544 is offline   Reply With Quote
Old Jul 24th, 2008, 8:04 pm   #2 (permalink)
lelenb's Avatar
Images: 12
I have done it. All you need is a hole saw that fits over the exit pipe and cut through. Drill out the rivets holding the aluminum decorative cap. Next cut off the end of the muffler after you make a few witness marks for alignment later. I used an air chisel to break the internal weld holding the exit pipe and then pulled out the pipe which takes some work as the inside end is slightly flared. Now weld back up the end using stainless rod or brazing as you do not want rust. Paint the welded area black and install the end pieces with new pop rivets and Bob is your uncle. Be sure to align the two drain holes on the bottom. If you do a search you should find at least one more post on this subject.
Lelen
Hyper S
Gettin' More Sound Out Of the Stock GT1000's Pipes. DUCeditor Sport Classic 283 Jan 6th, 2012 5:41 pm
Wow -- I like the stock gearing much better gregcm Sport Touring 2 Aug 31st, 2007 9:26 am
Full system ECU vs Stock rubyvrooom HyperMotard 13 Aug 29th, 2007 10:27 am
How much mileage did you guys get out of stock clutches? ThrottleJock Superbikes 25 Nov 28th, 2006 9:01 am
Is it possible to get a little more noise from stock mufflers? kurtfriedrich Superbikes 19 Nov 2nd, 2006 10:51 pm
