clutch wouldn't disengage after washing - Ducati.ms - The Ultimate Ducati Forum
Old Jul 20th, 2008, 10:42 pm   #1 (permalink)
freezer16801's Avatar
two days ago I gave the hyper a nice washing. I let her sit for a bit and I think some water pooled in my vented clutch. When I hopped on to ride to work, the bike lurched forward when I put it in gear with the clutch pulled in. I hit the starter and starter sequencer drove me around the driveway until I had enough brains to hit the kill switch. Once I was underway, the clutch cleared itself and every thing has been fine.
Has anyone had a similar problem? I've never experienced anything like this before. I initially thought that I introduced some air or water to the hydraulic system.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Jul 20th, 2008, 11:06 pm   #2 (permalink)
was it 2 days from when you washed it until you rode it again?
Old Jul 20th, 2008, 11:29 pm   #3 (permalink)
georound's Avatar
That's really common for the ducatis...the metal clutch discs start to rust and they stick to the friction plates. Once it jars loose and you use the clutch a bit, it'll be back to normal.
Old Jul 21st, 2008, 12:25 am   #4 (permalink)
AXE
AXE's Avatar
I recommend running the bike a little after a wash. This will blow out most of the water and heat up the plates and evaporate the rest. I don't have a problem with mine, but I heard others state this before, so I was prepared. You'll be good to go next time around.
Out!
2008 Ducati Hypermotard
Old Jul 21st, 2008, 1:13 am   #5 (permalink)
no the whole episode happened 2 days ago. I washed the bike, let it sit for a few hours and then when i went to ride it, the clutch wouldn't engage properly. Others explained it well. Now I can breath easily, thanks.
08 Ducati HM
Old Jul 21st, 2008, 8:38 am   #6 (permalink)
Get an air compressor for the garage and use it to blow the water out of the clutch, then run it for a few minutes and you should be fine.
Old Jul 21st, 2008, 9:49 am   #7 (permalink)
i was gonna say the same thing as the others, but wasn't 100% sure since i'm new to Ducati's as well.
here's a little tip. when i wash/clean engines, after i'm done i use a leaf blower to get water out of area's that i can't reach with a towel.
Old Jul 21st, 2008, 11:04 pm   #8 (permalink)
that is exactly what I will do next time.
08 Ducati HM
Old Jul 21st, 2008, 11:49 pm   #9 (permalink)
AXE
AXE's Avatar
Leaf blowers pick up a lot of dust and grit and spit it right on to your rig. Like hittin' it with some 100 grit sand paper.
Compressed air would be safer or you can get one of those bike blasters, which shoot filtered heated air out.
Out!
Old Jul 22nd, 2008, 1:13 am   #10 (permalink)
lots of people use it when detailing cars (even high $$$ cars) to get water out of the nook & crannies and even dry them so that touching the paint with a towel is kept to a minimum. i've never had a problem. also if it's just washed, the water around you keeps the dust low in the immediate area.
Ducati and After-market Clutch Master and Slave Cylinders Shazaam Hall of Wisdom 16 Dec 12th, 2011 4:30 am
New Clutch, Decisions, Decisions ... Shazaam Hall of Wisdom 6 May 19th, 2011 9:00 am
new clutch - won't fully disengage.. WRW Superbikes 11 Feb 25th, 2008 11:37 am
EVR Slipper Clutch - MUST SEE!!!!!!!!!!!! wrichards Superbikes 20 Nov 20th, 2007 10:46 am
Installed Pazzo Clutch Lever...now the clutch doesn't disengage 100% koolio Superbikes 11 Aug 18th, 2007 4:31 pm
