Experience with Power Commander - Ducati.ms - The Ultimate Ducati Forum
Old Jul 14th, 2008, 4:50 pm   #1 (permalink)
What's up
Anybody with feedback on the PCIII ?
worth getting?
Also, if you get cams and the ecu from Ducati, will the PC work with the new ecu?
My woman asked me for an inch. I gave her both of them.
Niss, P. is offline   Reply With Quote
Old Jul 14th, 2008, 5:28 pm   #2 (permalink)
Put mine on last week and it makes a huge difference.I will dyno tomarrow.Should be somewhere around 100 hp.I had the heads ported and polished cams degreed HC pistons Beast R intake>I did some roll ons with a buddy who has a 01 R6 with a pipe and spanked him to 120 .
Scotty
08 hypermotard S
08YZF250F SM
06WR450F SM
scottysspeedshop is offline   Reply With Quote
Old Jul 15th, 2008, 8:52 pm   #3 (permalink)
Besides everything else I just love the fact that you can also now use the quickshifter with it.
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline   Reply With Quote
Old Jul 16th, 2008, 2:18 am   #4 (permalink)
infidel's Avatar
What sort of money are the PCIIIs going for and wheres the best place to get them?
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Old Jul 16th, 2008, 4:17 am   #5 (permalink)
I noticed that there is a stock map available. Is there any advantage by using the PCIII on a stock bike?
SteveNC is offline   Reply With Quote
Old Jul 16th, 2008, 6:56 pm   #6 (permalink)
I got mine for $275 plus tax from my local dealer and I also added the quick shifter for $125.As for running it on a stock bike it will most likley smooth if out quite a bit.I do remember seeing som pc111s on fleabay for&259.
Scotty
08 hypermotard S
08YZF250F SM
06WR450F SM
Old Jul 16th, 2008, 7:02 pm   #7 (permalink)
georound's Avatar
On Craigslist (Orange county) there's someone selling for 269 with a free dyno run and he'll build maps for you if you change your setup. He'll ship with a custom map if you're not in the area.
I have no experience with them, just noticed while searching for ducati parts.
Old Jul 17th, 2008, 8:32 pm   #8 (permalink)
What about getting the race ecu *and* the PCIII?
I guess my question is this: When you get the cams, you get an updated ecu. What if you can get cams really cheap, but they don't come with the ecu - will the PCIII get the same results? -OR- is it better to get the new ECU *with* the PCIII?
Hopefully I'm more clear now...
Old Jul 17th, 2008, 8:47 pm   #9 (permalink)
MarksFriggin's Avatar
The PCIII won't change the stock ECU settings below 25% throttle, so you pretty much have to get the performance ECU if you want to use the PCIII.
Old Jul 17th, 2008, 10:57 pm   #10 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Also, the DP ECU from the cam kit has a little more ignition advance dialed in. I don't think you can alter ignition advance with just the PCIII USB EX (for the stock ECU). You will need the separate Ignition module which I think is only available for use with the PCIII USB Race.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Sport Classic 1000S Dyno Run - Power commander & Termi's glenndesmo Sport Classic 9 May 14th, 2008 12:41 am
Power Commander on 620ie help lurching? Tardus Sport Touring 1 Mar 24th, 2008 12:15 pm
Power Commander question Gary02ST4S Sport Touring 25 Feb 12th, 2008 8:39 am
Power Commander 3 USB for the SCand PS for 06 and 07 "Graphs and Dyno" PSLE1000 Sport Classic 37 Nov 27th, 2007 4:18 pm
998 Power Commander III jules_1972 Superbikes 1 Jan 17th, 2006 2:14 am
