Beast R Intake? - Ducati.ms - The Ultimate Ducati Forum
Old Jul 12th, 2008, 6:21 pm   #1 (permalink)
Enigma's Avatar
Beast R Intake?
Which TPO intake do i need for my tard, for those who have done it, is it the "Beast" or the "Beast-R?"
Enigma is offline   Reply With Quote
Old Jul 13th, 2008, 12:34 am   #2 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Either one, the Beast for low end, the R for mid and top end power. I'm running the R. You'll need A Dp ECU or some means of adjusting your fuel map to compensate for less intake restriction. You should also have at least a slip-on exhaust.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Jul 13th, 2008, 10:24 pm   #3 (permalink)
Enigma's Avatar
its at the DucShop right now getting built. thanks for the input
Old Jul 13th, 2008, 10:49 pm   #4 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Nice! Post a report when you get your bike back.
-2008 Hypermotard S
-2005 Buell XB9SX
-2005 CRF170R
Old Jul 14th, 2008, 7:50 pm   #5 (permalink)
Tickwomp's Avatar
The sound alone....
makes the beast r a great deal.
I'm running the 'r' myself and got say that .5 to full throttle sounds freakin' awesome. Bike pulls harder everywhere ( and dropping 4 lbs doesn't hurt either).
Going on vacation shortly and will drop bike off for tuning, and looking forward to posting the dyno. That said, the guy that did my cams told me straight up that I'm going to lose power, and that the stock air box is best.
I'm trying to swing a deal that if it makes more power with the Beast r, he'll do the tuning for free;-) (my hole card is I was running the -1 front sprocket, and bikes with lower gears chart lower on the dyno. I am now running stock gearing)
ken
08 Hyper S
07 XR650R Sumo'd (recently sold, but not forgotten(
98 CR250R
84 KZ1000
Tickwomp is offline   Reply With Quote
Old Jul 15th, 2008, 3:07 pm   #6 (permalink)
Enigma's Avatar
yeah thats why it would be best to use to high compression pistons with the cams
Old Jul 15th, 2008, 8:47 pm   #7 (permalink)
I run the R kit as well, went from 105.15hp to 107.37hp and 76.69 to 80.40 on the tourque. Had a little dip in the fuel curve that was fixed quickly through adjusting the map on the PCIII.
All the power gain was between 4200-8400 revs.
I would say it was worth it
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline   Reply With Quote
Old Jul 15th, 2008, 10:56 pm   #8 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
That's very impressive! Must be fun to ride. I had across the board gains with the Beast R but my engine is stock. Here is a before and after chart.
-2008 Hypermotard S
-2005 Buell XB9SX
-2005 CRF170R
Old Jul 16th, 2008, 11:15 pm   #9 (permalink)
These are some great numbers for a stock motor, should be a keeper.
Old Jul 17th, 2008, 3:41 am   #10 (permalink)
Dukepilot, where was your dyno done? Is that Nichols`? I know they all vary but damn! You have about 7 pds more torque and only 5 less horses then me and my motor is built.
85' Yamaha RZ350
06' MV Agusta Brutale 910s
07' Triumph Daytona 675
08' Ducati Hypermotard 1100
frique is offline   Reply With Quote
TPO Beast Intake for monster on SC mattgregg Sport Classic 22 Mar 24th, 2011 9:59 pm
MS4R valve clearances and intake valves dirty? carlosbarrios Ducati Motorcycle Chat 2 May 28th, 2008 10:17 am
Anyone use the TPO Beast Intake? corky4891502 Monster 2 Jan 24th, 2008 10:43 pm
High Compression Piston info PLEASE.... 08hyper HyperMotard 11 Dec 1st, 2007 9:44 am
Desmo valve system,, Is it out dated?? AzThumper Ducati Motorcycle Chat 173 Jul 5th, 2007 11:55 am
