Chain adjustment clarification - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com Classifieds!
Old Jul 9th, 2008, 10:38 pm   #1 (permalink)
parkcrf's Avatar
I just bought the service manual and am confused on one piece of the chain adjustment. What and how is this done?
Wheel axis (R) must remain below eccentric hub axis (E) during the whole operation.
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Jul 9th, 2008, 11:00 pm   #2 (permalink)
I'm not sure what the confusion is, but basically, if you look at the eccentric hub, the axle hole is off center (which is literally what "eccentric" means).
DISREGARD THE FOLLOWING!
[The range of chain adjustment moves the axle hole in a "U"-shape within the hub, or in the bottom half of the hub.]
Move the adjuster ring back and forth, and watch how the axle moves in relation to it, and you'll see what I mean.
(This is one of the drawbacks of an eccentric chain adjuster. As you adjust the chain throughout its life, the ride height of the bike actually changes with it. Most people will never notice the difference, though.)
I hope this 'splains it...
Old Jul 9th, 2008, 11:21 pm   #3 (permalink)
parkcrf's Avatar
Thanks AZScott! I've only done dirtbike chains before
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Jul 9th, 2008, 11:38 pm   #4 (permalink)
Okay, my bad!
I just took a look at my own bike, and the axle is definitely in the TOP half of the eccentric hub! So unless I'm completely on drugs, the illustration you posted is incorrect.
Can anyone verify my sanity here?
Old Jul 9th, 2008, 11:46 pm   #5 (permalink)
Upon further investigation, the illustration seems to be for the 916 series hub. On those bikes, the axle is "low". But on the Hyper, it should be "high".
If you crouch behind your bike, eye-level with the swingarm, look at the adjustment ring, and then notice where the axle is. On the Hyper, it should be ABOVE center.
Sorry for adding to your confusion!
Old Jul 10th, 2008, 12:04 am   #6 (permalink)
tunefx's Avatar
Park, I'm with you! And, I keep looking at my chain thinking it's time to dive in. The good news is we don't have to worry about alignment!
I have an embarassing question. What tool should I use to turn the eccentric hub? Note: I did not get a tool kit with this bike (bought used). Did the tool come with the kit? Other options?
'08 HM 1100 S
tunefx is offline   Reply With Quote
Old Jul 10th, 2008, 12:22 am   #7 (permalink)
That little chain guard thing over the rear portion of the chain is connected to the adjuster ring. Once the two pinch bolts are loose on your hub, you can move the chain guard piece to turn the ring...
Old Jul 10th, 2008, 12:51 am   #8 (permalink)
parkcrf's Avatar
I bought a tool from Motowheels. They have it on their website.
Thanks AZScott for the help!
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Jul 10th, 2008, 7:32 am   #9 (permalink)
GMP
A shock spring preload tool (Ohlins) I have works too but its just easier to use the chain guard.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Jul 10th, 2008, 7:45 am   #10 (permalink)
what's the torque setting on the pinch bots? 28nm?
Karlr is offline   Reply With Quote
Chain Cleaning, Waxing and WD-40 Shazaam Hall of Wisdom 41 May 9th, 2012 4:11 pm
Chain Inspection and Freeplay Adjustment Shazaam Hall of Wisdom 1 Jan 10th, 2012 11:41 am
999s Gearing Change Soarer Superbikes 8 Jul 18th, 2007 10:45 am
916 chain adjustment - need a little clarification dragknt Superbikes 8 Oct 22nd, 2006 9:07 am
