Problem: Front forks and Brake lines rubbing. - Ducati.ms - The Ultimate Ducati Forum
Old Jul 9th, 2008, 5:52 am   #1 (permalink)
Anyone else have issue with front forks and the brake lines, mine are rubbing against the fork walls, gold color is gone already and i have some wear on brake lines, anyone else have this issue?
sakucee is offline   Reply With Quote
Old Jul 9th, 2008, 6:39 am   #2 (permalink)
Hi yes mine was the same you need to rotate the carriers (little metal bits where the brake line is held on fork clamps) so that the lines clear the fork legs. You need to twist them and keep checking. For Ducati...bad design.
Karlr is offline   Reply With Quote
ST3 Suspension Upgrades - Forks Ducati23 Sport Touring 29 Mar 18th, 2011 7:29 pm
hyper S - problem with brake lines? geoff1121 HyperMotard 4 Jun 7th, 2008 6:55 pm
Used 748-998 Ohlins Front Forks/ Lower Triple moto Motowheels 0 Jun 23rd, 2007 7:10 pm
Galfer front brake lines with Heli bars. 748 VolvoWrench Superbikes 1 Jan 26th, 2006 10:00 pm
