HM Tail Chop - Termi signal bracket - Ducati.ms - The Ultimate Ducati Forum
Old Jul 8th, 2008, 3:59 pm   #1 (permalink)
TurboMonster's Avatar
I'm working on the tail chop for my HM...
1) Using the R&G Racing plate holder (Mod: Remove the signal mounts)
2) Making a rear turn signal relocation bracket similar to the one that come with the Termignoni exhaust kit*
3) Using black Rizoma Avio 21 turn signals. Note: Turn signals are 6 volt (supplied with a 12 to 6 volt converter).
4) Mounting a rear view video system, with the camera mount above the exhaust cans.
My project, if anyone has any suggestions...
http://www.duccutters.com/BillJohnson-furia.tpl
*I went to three Ducati dealers and they all said I couldn't buy just the rear turn signal relocation bracket Termignoni exhaust kit. But they loaned me one for the weekend, so I drew it up. I was wondering if anyone else is interested in a Termi style bracket? If so, I can have a batch water-jet cut and produce a few of them. If not, I'll just hand cut one for myself this weekend.
If your interested is making your own...
http://www.duccutters.com/johnson/Mo...HM-RTSRB-T.pdf
TurboMonster is offline   Reply With Quote
Old Jul 8th, 2008, 5:12 pm   #2 (permalink)
i just ordered my relocation bracket today, so the relocation kit is available. it was ~$17
i don't have the part# on me at the moment though
Old Jul 8th, 2008, 5:21 pm   #3 (permalink)
Wow, please post the part number!
Wow, please post the part number! It's not worth $17.00 for me to waste the time making one.
Thanks!
Old Jul 8th, 2008, 6:26 pm   #4 (permalink)
theduke's Avatar
Images: 2
Be aware that fitting the Termi indicator re-locating bracket will stop a passenger from using the grab rail at the back, I had to modify my bracket (bend it downwards) to give enough clearance for my passengers to be able to use the grab rail... I fitted this last week and came across this problem but have worked around it.
1098 S (2007)
HM S (2008)
theduke is offline   Reply With Quote
Old Jul 8th, 2008, 6:44 pm   #5 (permalink)
Part Number: 96761308B
for some reason it comes up as a "Headlight Bracket"
Old Jul 9th, 2008, 12:14 am   #6 (permalink)
blitzenduden's Avatar
no pictures!?
here is my work... took the subframe off and had it match powder coated Ducate red. Yes the rear assembly is a piece of agile manufacturing wonder.....geez.
Took the cheap plastic termi body work and had it wet painted Ducati red.
Took the metal substructure of the licence plate holder and welded a strip plate on it to clean up the back, mounted both the plate and the plate light to the strip plate. came out pretty clean. The licence plate is offset to avoid the exhaust. It is tastefully done... doesn't look like one of those slammed mini truck plates.
blitzenduden is offline   Reply With Quote
Old Jul 9th, 2008, 7:15 am   #7 (permalink)
Images: 5
Looks good. It's possible to mount the number plate and light to the exhaust bracket mounting piece of the sub frame which cleans up the rear end no end. But, a 7"x5" plate is required, simple bracket to be fabricated, and most important make sure the rear end is not to saggy so that their is no licence plate / rear tyre incidents... Hopefully the link below will take you to some gallery picks of what i am talking about.
http://www.ducati.ms/gallery/browsei...mageuser=26217
Hypermotard
Husaberg FS650
ZX10 R
Chris Neeves is offline   Reply With Quote
Old Jul 9th, 2008, 8:34 am   #8 (permalink)
Jeff4510's Avatar
Is there a picture of this Termi relocation bracket? Edit: I looked at your links, I am looking for one for the termi 2-1 which is likely different if it even exists?
08 HM S
05 CR500AF street project
05 CRF450X super moto/streeted
1985 Vespa ETS 125
1977 R100/7
Jeff4510 is offline   Reply With Quote
Old Jul 9th, 2008, 10:02 am   #9 (permalink)
the part # that i listed is for the 2-1 bracket.
got the # from theduke's thread
Rear Turn Signals Relocating Kit
Old Jul 9th, 2008, 2:10 pm   #10 (permalink)
Jeff4510's Avatar
that looks like a turn signal relocate bracket and the plate seems like it's lifted a tad but keeps all the original plastic. I'd really love a pic of the 2-1 bracket fitted or just the bracket if someone has Tia!
08 HM S
1985 Vespa ETS 125
1977 R100/7
FYI Tail Chop Part 1 - cost $12.66 mattgregg Sport Classic 4 Sep 25th, 2008 11:57 pm
WASP Tail Chop: Pictures don't do it justice lordzeus Sport Classic 7 May 4th, 2008 11:35 pm
Wanted: Tail chop and signal relocation kit TurboMonster HyperMotard 0 Jan 18th, 2008 10:44 am
Matts Tail Chop Part 2 - The Finally Stealth Tail! mattgregg Sport Classic 5 Jan 14th, 2008 9:51 pm
Fender eliminator + tail chop ducadent Sport Classic 55 Jul 31st, 2007 11:48 am
