Jul 4th, 2008, 6:49 am
Scotts Damper Installed! Nice!
Well after reading the Ducatisti who are against the dampers, I did purchase one and did put it on. I agree suspension is key to removing headshake and track loading, I just felt the need for another degree of anti-slappage. May be bling, but you can't mess with Scott's quality and performance.
So here goes:
First, let me say that Scott's instructions and the kit itself are complete. The install went smoothly as these guys really put an effort into making sure you're covered.
Kit as it came (even with blue loc-tite) -
Took off top clamp and key cover-
Unplugged anti-theft from left side on frame -
Key cover and anti-theft device -
Fancy towel holder with duct tape, lower perch removed -
Lower OEM washers placed in Scotts lower perch -
Lower perch installed -
HARD PART! GRAB ANOTHER BEER. - Removed anti-theft ring from key cover -
This takes patience, the ring has two tabs holding it down and some light glue. The glue is the beotch to slowly pry away. Used a very small set of flatheads. DO NOT BREAK THE PLASTIC RING.
OEM ring installed in Scotts delrin (?) housing. The cut out from Scotts fit nicely.
New housing snapped into key cover (press fit, added loc-tite). Locked down with acorn nuts and and floating pin greased and in place -
Damper in place -
Top clamp on -
Done and done.
Overall, I love the infinite adjustability and the comfort of knowing not only my suspension will be dialed in, but I have a back up for the accel out of track day curves. Scotts is half the price of Ohlins and the same device.
JCB
2010 1198
Full Termi, DP Race Seat, SpeedyMoto Clutch Cover & Plate, Pazzo Levers, EVR Clutch Slave
2008 HM-S Black (sold and miss it...)
DP Full 2-1 Termi, DP Race Seat, Pazzo Levers, Scotts Damper, MotoVation Sliders, DP Carbon Parts
Jul 4th, 2008, 8:07 am
JCB,
Well done! Thanks for the pics and tips. Very helpful!
'08 HM 1100 S
Jul 4th, 2008, 8:54 am
Yep, absolutely top job with the pics and info... You answered all questions I had about this from the other thread!
Muchos gracias.
Oh, and it looks the goods too..
p2e.
: p ~
Jul 4th, 2008, 10:20 am
Tested...
Took it out for about 120 miles today...feels good...looks good.
Me likey.
JCB
2010 1198
Jul 4th, 2008, 11:20 am
Got mine yesterday... will hopefully be installing this weekend... thanks for the detailed install pictorial. Will definitely make the job easier.
B
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Jul 4th, 2008, 3:35 pm
Me likey.
Great pics!! thank you, but I have a question, with the new bar clamps are the
handlebars in a higher location? or are they at the stock height? thanks, Alex
PS: how much was the kit?
Jul 4th, 2008, 6:42 pm
Very nice. Thanks for posting the pics!
Jul 4th, 2008, 9:58 pm
Lifetime Premium
Beautiful...I'm sure a sucker for blacked out components.
One of the nicest things about this kit is you don't have to remove the upper triple clamp to mount the post. Until I say your pictures, I did not realize this important fact.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Jul 5th, 2008, 10:31 am
OEM height from what I gathered from the Scott's website.
B
'05 BMW K1200LT
'10 BMW S1000RR
Jul 5th, 2008, 1:20 pm
OEM height from what I gather. Still feels the same after install for the height.
Kit is $599, but as one of the lucky first purchasers, I got mine for much less.
JCB
2010 1198
