Termi heatshield - Ducati.ms - The Ultimate Ducati Forum
Old Jun 21st, 2008, 8:22 am   #1 (permalink)
Termi heatshield
Hey guys,
just picked up my new Hyper s with Termi slip-ons and de-cat pipe - sounds great, my first Duc with these... One question, I notice it only has heatshield material under the left [looking from back] carbon tail piece. Is this because most of the gas exits this side or did they just have a holiday here and not put it on?
cheers
chunda is offline   Reply With Quote
Old Jun 21st, 2008, 8:43 am   #2 (permalink)
tunefx's Avatar
Congratulations on the bike! I have the same set up but I will have to go look and see. I'm too new on the bike to have it all in memory--yet.
'08 HM 1100 S
tunefx is offline   Reply With Quote
Old Jun 21st, 2008, 10:37 am   #3 (permalink)
Motard-Menace's Avatar
I don't have the slip-ons but I do remember others with that set up talking about how a majority of the exhaust flows out one side so you may be on to something with that line of thinking. I only have one pipe, so no worries.........
I'm sure one of the guys on here with that set up will chime in. BTW Welcome.
MOTARD-MENACE
07 BMW F800S
Old Jun 21st, 2008, 11:38 am   #4 (permalink)
theduke's Avatar
Images: 2
Originally Posted by chunda View Post
Hey guys,
cheers
I have the Termi slipons and mine has heat shielding both sides?
1098 S (2007)
HM S (2008)
theduke is offline   Reply With Quote
Old Jun 22nd, 2008, 9:01 am   #5 (permalink)
Ok
thanks for that - guess they can just order it in for me - apart from that, life is good!
cheers
2 into 1 Termi install and Exhaust plugs weaselberry Sport Classic 1 Jul 24th, 2009 2:14 am
Mid Pipe for Termi Slipon hendricks HyperMotard 7 Mar 20th, 2008 7:42 am
the full termi is a DEAL at $2000 rubyvrooom HyperMotard 81 Jan 12th, 2008 12:38 pm
Termi 2:1 v. 2:2 geospencer Sport Classic 6 Nov 1st, 2007 7:48 pm
Advice needed 749 w/ Termi ECU? sludge Ducati Motorcycle Chat 3 Jun 8th, 2007 6:16 pm
