Please Seal Your Subframe ends - Ducati.ms - The Ultimate Ducati Forum
Old Jun 18th, 2008, 8:19 am   #1 (permalink)
HyperMotard21's Avatar
Images: 61
After spending a good whole afternoon washing my bike for the first time since I got the bike, I was freaking out the next day after my ride.
I found dried rust water, lots of it, that had trickled along my silencer.
I couldn't figure out at first where it came from but realized it came out of my 4 opening at the end of the subframe.
Overnight the water that had entered from washing, and possibly wet rides had gotten in, more in my case as I use a DP luggage rack (it moves the plastic bit that bolts the rearlight, further away from the ends of the subframe end holes)
It had apparently come out while I did my wheelies. For those who are not a retard like me, I have no idea how you would remove any water if any already accumulated before sealing.
You'd think a maker like DUCATI would not try and save fifty cents and leave a subframe needing replacement after a couple of years from RUST
A HyperTard on a HyperMotard
HyperMotard21 is offline   Reply With Quote
Old Jun 18th, 2008, 9:41 am   #2 (permalink)
lelenb's Avatar
Images: 12
Thanks for the heads up.
Lelen
Hyper S
Old Jun 18th, 2008, 10:05 am   #3 (permalink)
Images: 61
Would drilling a tiny hole at the bottom bit of the subframe help water flow out THEN seal the top (and bottom) with a cap or silicon?
Old Jun 18th, 2008, 12:07 pm   #4 (permalink)
bromike666's Avatar
Try out some of the new wipe down products instead. If you wipe it after every ride there is no reason to get out the hose. I give my bike a light wipe down w/ WD40, Plastic Cleaner and Cleaning Wipes after each ride and then do a HUGE cleaning every month or so. The only water to ever touch my Hyper was that rainy day w/ Tamir, Alex & Sparks.
"I love the sound of a dry clutch in the morning"
10 F1098S Streetfighter
08 Hypermotard 1100S
08 Multistrada 1100S
07 SM610
bromike666 is offline   Reply With Quote
Old Jun 18th, 2008, 12:15 pm   #5 (permalink)
sloduck's Avatar
The subframe supposed to be aluminum, therefore they don't rust.
sloduck is offline   Reply With Quote
Old Jun 18th, 2008, 12:53 pm   #6 (permalink)
No, you can buy aftermarkte aluminium subframes but the stock one is steel, very poorly welded steel at that.
gossa is offline   Reply With Quote
Old Jun 18th, 2008, 2:06 pm   #7 (permalink)
sloduck's Avatar
My bad!
Old Jun 18th, 2008, 2:57 pm   #8 (permalink)
yota's Avatar
pretty sure some nice plastic (bogus plastic) plugs could be found for this purpose.
yota is offline   Reply With Quote
Old Jun 18th, 2008, 3:51 pm   #9 (permalink)
johnchypermotard's Avatar
yeah, baby!!!!
i am heading down to local hardware store to check out the plastic bung hole plug selection they have.
Old Jun 18th, 2008, 5:09 pm   #10 (permalink)
Werloc's Avatar
Images: 6
Yeah, You can find plugs at a good mom & pop hardware store. ACE, or True Value have all those bolt bins with odd ball stuff. Lowes & Home Depot are less likely to have these. I'll also pick up "bung-hole" plugs.....LOL
Good idea....
Werloc is offline   Reply With Quote
Corsa RS subframe - Help needed! (and subframe) TAftonomos Superbikes 6 Mar 30th, 2008 7:23 am
748-998 Subframe update 1fast750ss Superbikes 5 Jan 18th, 2008 8:04 pm
Ugh. Changing mono subframe to biposto subframe... Dana Superbikes 5 Nov 13th, 2007 5:15 am
speedometer drive seal fastlarry Superbikes 0 Apr 7th, 2006 6:58 am
