Specs for the standard:
Frame: Tubular steel Trellis frame
Wheelbase: 1455mm / 56.9in
Rake & Trail: 24°
Front Suspension: Marzocchi 50mm fully adjustable upside-down fork
Front Wheel Travel: 165mm / 6.5in
Front Brake: 2 x 305mm semi-floating discs, radially mounted Brembo calipers 4-piston, 2-pad
Front Wheel: 5-spoke in light alloy 3.50 x 17
Front Tire: 120/70 ZR 17
Rear Suspension: Progressive linkage with fully adjustable Sachs monoshock. Aluminium single-sided swingarm.
Rear Wheel Travel: 141mm / 5.6in
Rear Brake: 245mm disc, 2-piston caliper
Rear Wheel: 5-spoke light alloy 5.50 x 17
Rear Tire: 180/55 ZR 17
Fuel Capacity: 3.3 gallon (US)
Dry Weight*: 179kg / 394lbs
Seat Height: 845mm / 33.3in
Instruments: Speedometer, rev counter, clock, maintenance schedule, oil temperature, oil pressure warning light, battery level, fuel reserve warning light, trip fuel, indicator light, neutral light, injection system diagnostics, lap time memory storage, automatic light-off function after 60 secs key-on, immobiliser. The instrument panel menu functions are controlled from the left-hand switchgear.
Warranty: 2 years unlimited mileage
Color combinations (Tank-Frame-Wheels):
Versions: Biposto / Dual seat
MOTARD-MENACE
07 BMW F800S
