Got it - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Jun 17th, 2008, 7:37 am   #1 (permalink)
HyperWeaseL's Avatar
Got it
I picked up my Hyper S on friday after waiting 3 months for it,sounds v cool with Termi2-1,i only done 40 km on it friday and have been home ill with flu trying to get better so i can go out on it.
I have never owned a new bike befor and the gear lever is a bit stiff and i can't find neutral,i am sure this will losen up.
Hope i get better soon i am going mad in the house"NEED TO GO OUT ON BIKE"
HyperWeaseL is offline   Reply With Quote
Old Jun 17th, 2008, 9:00 am   #2 (permalink)
shat's Avatar
I switched to Royal Purple full synthetic at 2500 miles and noticed a huge difference in shifting. Give yours til the 600 using the following and enjoy:
http://www.mototuneusa.com/break_in_secrets.htm
ciao
shat is offline   Reply With Quote
Old Jun 17th, 2008, 3:17 pm   #3 (permalink)
Caidly's Avatar
Just got mine home yesterday. S in Black. Same neutral issues.
Old Jun 17th, 2008, 3:20 pm   #4 (permalink)
if you guys haven't had Ducs before then it might just be adapting to them, they are harder to find than jap bikes if you happen to be transferring across.
If that's not the case then I'd talk to your dealer, neutral is fine on my bike, always has been from new.
gossa is offline   Reply With Quote
Old Jun 17th, 2008, 4:37 pm   #5 (permalink)
GHEZZI's Avatar
Always ride a Guzzi for 3 years minimum before buying a Ducati, my gearbox is perfect.
Old Jun 17th, 2008, 7:22 pm   #6 (permalink)
lelenb's Avatar
Images: 12
The clutch, brakes and other components should improve in feel by the time you need your 1000k first oil change. Get better soon so you can enjoy what you have.
Lelen
Hyper S
Old Jun 17th, 2008, 7:50 pm   #7 (permalink)
jediduc's Avatar
I had some issues with neutral as well. I had trouble at long lights, just going back and forth between first and second. With the motor stopped, no problem finding neutral, and feels good at the foot. What I discovered that works, is that when rolling up to what I know will be a long light, while bike is still rolling, I pull in the clutch, and do a light tap from second, there's neutral. Seems to work all of the time. Don't know if the bike rolling has anything to do with it, but has certainly worked well for me. Be wary of the light as well.
'10 Streetfighter S
'08 Hypermotard S
a man's got to know his limitations.
jediduc is offline   Reply With Quote
Old Jun 17th, 2008, 8:55 pm   #8 (permalink)
GHEZZI's Avatar
Originally Posted by shat View Post
Just spent an hour or two on that sight.
The nephew had his first track day 2 days after I bought the Hyper and it pissed rain for those 2 days. The plan was to nock up 800klm on the Saturday and join him Sunday morning to show him my hallowed turf.
So with only 120klm on the clock I spent the next 120k trying to keep it to half throttle and 6000rpm max, even doing whole laps in 6th gear I was passing people.
Anyhow, it's the hardest run-in procedure I've ever used, and all is fine.
LOVIN' IT
Old Jun 17th, 2008, 9:04 pm   #9 (permalink)
Jediduc said it above but it bears repeating. Beware of the neutral light. It can give false readings.
pchmotoho is offline   Reply With Quote
Old Jun 17th, 2008, 9:05 pm   #10 (permalink)
HYPERR's Avatar
Really?? I always thought dry clutches were always easier to find neutral than a wet clutch. I have no problems finding neutral in both my dry clutched bikes.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
