So I removed the throttle tube, cables, brake and handguard to slide a basic mount down the handlebar for my Quest 2 GPS. Upon reassembling the throttle I noticed that it had an easier twist and seemed not to require as much effort to turn it. I got a bit worried that I may have installed the two cables in reverse because there was now a slight twisted look to the cables which I hadn't notice before.
Anyways, I went out for a ride to try out the GPS through town and this was when I noticed that the throttle felt MUCH MORE CONTROLLED and smooth and it no longer had the herky-jerkiness going on and off throttle driving around town. Before it seemed to act more like on-off then gradual power when you started to twist it, so I had to be extremely careful. Having never owned a Ducati before I assumed this might just be how they run.
OK, this is the other thing I noticed, before the throttle reassembly the bike used to make a gurgle and some slight popping sounds under heavy engine braking (actually thought it sounded cool) and also seemed to have alot more aggressive braking off-throttle - This is gone now too!
I'm wondering, has anyone else reversed their cable leads at the handlebars and noticed a big difference?
I'm not even 100% sure I messed up the reinstall, but I think its entirely possible the dealer could have installed it backwards prior to delivery. It feels like night and day to me from before!
