Sounds to me like your dealer either hasn't lined up the mark on the pressure plate with the slotted post on your clutch, or not tightened up the springs properly.
The 1st error would prevent the teeth on the back of the pressure plate properly engaging with the teeth on the clutch, thus causing slippage.
The second would result in slippage too. They should be tightened to 5nm or if your torque wrench doesn't go down that low, fully in, then another 1/8th or so of a turn.
Worth checking both, will only take 10 mins.
Edit: just a thought, you didn't buy a pressure plate meant for a slipper clutch did you, I think they're different (I'm not 100% sure on that so willing to be corrected!
