How often do you adjust the chain? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comGraves MotorsportsMotorcycle.com Classifieds!
SportbikeTrackGear
Old Jun 10th, 2008, 8:40 pm   #1 (permalink)
alounacara's Avatar
And how much slack should there be when you are finished?
2008 Hypermotard
1994 ZX9R Kawasaki gone and good riddance
Houston Texas
alounacara is online now   Reply With Quote
Old Jun 10th, 2008, 8:48 pm   #2 (permalink)
johnchypermotard's Avatar
there is a sticker on the swingarm that indicates where to measure the chain slack, and how much slack to adjust to.
here is the description for chain adjustment from page 76 in the owners manual:
Checking drive chain tension (fig. 65) Wheel the motorcycle back and forth until finding the position at which the chain is tightest. Place the motorcycle on the side stand. Place the rule in front of the chain guard, push down on the chain and release it.
Tension up until the distance between the aluminium section of the swinging arm and chain pin centre is 30 ÷ 33 mm.
Important
Have chain tension adjusted by a Ducati Dealer or Authorised Workshop.
Warning
Correct tightening of swinging arm screws (1, fig. 66) is critical to rider and passenger safety.
Important
Improper chain tension will lead to early wear of transmission parts.
Old Jun 10th, 2008, 10:30 pm   #3 (permalink)
Tickwomp's Avatar
OEM Chain is Awesome
I've just done 6K miles, and it seems like most of it has been on the rear wheel. I've adjusted the chain 3 times, and the last time it didn't really need it. (and i'm running the 14 front, which the big brains on this board will tell you is harder on the chain and sprockets than the 15)
Not to hijack your thread, but I'm wondering if the 520 Conversion holds up well.
ken
08 Hyper S
07 XR650R Sumo'd (recently sold, but not forgotten(
98 CR250R
84 KZ1000
Tickwomp is offline   Reply With Quote
Old Jun 21st, 2008, 4:34 am   #4 (permalink)
Johnb250's Avatar
Ok I've read all the threads on chain tension/adjustment and it seems most are measuring from the aluminium swingarm and not the slider, surely this is too tight ! The 2008 cd manual shows different (I think 'bad image'), see pic.
Johnb250 is offline   Reply With Quote
Chain Cleaning, Waxing and WD-40 Shazaam Hall of Wisdom 41 May 9th, 2012 4:11 pm
Chain Inspection and Freeplay Adjustment Shazaam Hall of Wisdom 1 Jan 10th, 2012 11:41 am
Chains and oiling duckbrand Superbikes 31 Mar 21st, 2008 2:33 am
999s Gearing Change Soarer Superbikes 8 Jul 18th, 2007 10:45 am
