Lights @ track days - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comGraves MotorsportsMotorcycle.com Classifieds!
SportbikeTrackGear
Old Jun 10th, 2008, 1:26 pm   #1 (permalink)
Lights @ track days
I'm taking my Hyper to a track day for the first time this weekend and have a question. What is the easiest way to turn off the headlight and tail/brake lights? On my GS I could turn off the headlight holding a switch during the start up procedure and removing the rear bulb was an easy two screw deal.
So - what do you guys do? Any suggestions?
dudecati is offline   Reply With Quote
Old Jun 10th, 2008, 1:43 pm   #2 (permalink)
theduke's Avatar
Images: 2
Unhappy
Not sure, I always disconnect the bulb connector on my 1098, on my Hyper I did a full days track day and taped the front light up and found its melted the lense slightly, so well worth disconnecting next time!
1098 S (2007)
HM S (2008)
theduke is offline   Reply With Quote
Old Jun 10th, 2008, 1:50 pm   #3 (permalink)
Ducati Ambassador to the Vatican
brust60's Avatar
I always pull the fuse for the front and disconnect the plug under the seat for the rear.
brust60 is offline   Reply With Quote
Old Jun 10th, 2008, 3:52 pm   #4 (permalink)
piarjr's Avatar
Cool
yeah I do the same !!!
piarjr is offline   Reply With Quote
Old Jun 10th, 2008, 3:54 pm   #5 (permalink)
That sounds like the way to go. Next stupid question - where is the fuse for the front located?
Old Jun 10th, 2008, 4:40 pm   #6 (permalink)
hyprduc's Avatar
I unplug both and it only takes a minute. I zip tie the headlight connector to the frame to ensure it doesn't wedge itself in the steering. I may try removing the fuse for the next track day though.
Cheers
hyprduc is offline   Reply With Quote
Old Jun 11th, 2008, 6:46 am   #7 (permalink)
GHEZZI's Avatar
Doesn't one of our boffins sign off with:
IF YOU CAN'T FIX IT WITH A HAMMER, IT'S NOT ELECTRICAL!
This would be your quikest fix, wouldn't it?
Old Jun 11th, 2008, 10:00 am   #8 (permalink)
Yeah but I can't imagine the cost to replace the lheadlight when leaving the track!!!!
Barber June 14th &15th - Track Days For Sale Pirate Ducati Motorcycle Chat 1 May 30th, 2008 6:07 pm
Swindlers guide for track days theduckllr Ducati Motorcycle Chat 7 Apr 10th, 2007 12:07 pm
Track days dangerous? Geronimo Superbikes 35 Jun 13th, 2006 7:58 pm
