Jun 9th, 2008, 8:02 pm
Flywheel Install Questions
Is this a do it yourself type job? Any gotchas I need to be aware of?
I'm going to install a sweet set of the Sato (black) rearsets and was thinking of knocking out the flywheel while I was kinda in the area.....
ken
08 Hyper S
07 XR650R Sumo'd (recently sold, but not forgotten(
98 CR250R
84 KZ1000
Reason: spell error
Jun 9th, 2008, 9:10 pm
If you search I did a little write up on how I did mine. It's pretty easy on this bike. If you have the footpegs off then you are half way there.
Jun 9th, 2008, 10:01 pm
Here is a link to one of the flywheel discussions. I list the tools you need to perform the job. The one thing I did not list is a side case puller. I just used two metric bolts that were longer then the bolts shaft cover. I used a small puller that I had, but it would be easy enough to make something your self. Just don't use the stock shaft cover as it might break because it is a cheap cast piece. The only thing the puller really does is to break to sealant from the factory.
Light flywheels are they worth it?
Lelen
Hyper S
Jun 10th, 2008, 1:42 pm
Hey SPEEDFREAK,,
I have read many opinions on the light flywheel, What is your opinion???
Black Carbon Diavel
848 EVO
Jun 10th, 2008, 9:19 pm
I love it. If your bike is tuned right it will rev faster, pull harder and even pull away from stops easier. It will also flick quicker in corners. I see no downside to the flywheel now that I have put it in and ridden it.
Jun 10th, 2008, 10:25 pm
Which one did you use?
I'm getting ready to pony up and get the Nichols.
ken
08 Hyper S
98 CR250R
84 KZ1000
Jun 11th, 2008, 6:37 pm
Yep, Nichols is what I have. It's over 3 1/2 pounds lighter than the stocker!
Jun 11th, 2008, 7:00 pm
Ordered the
Nichols this afternoon w/2 jam nuts for insurance.
ken
08 Hyper S
98 CR250R
84 KZ1000
