Ok so ive been over in the shed cutting away at my exhaust, so i thought id better show you what ive been up to.
I read lots of posts warning not to cut it up but i just couldnt help it.
So 1st up i cut the zip ties that hold the exhaust sensor wires (they run along the right hand side and then across the top of the horizontal piston) and then unplug the sensor wire.
Now that is disconnected you can undo and drop the rest of the exhaust and unscrew the sensor from the cat pipe.
When you are pulling the exhaust apart you can remove the cables that operate the exhaust flap (in the pipe before the mufflers). Then you can leave the little electric motor plugged in and wont have engine light problems.
Emptying the cat......now this is a bit of a bitch. you will need to cut just next to the weld around the exhaust side with your hacksaw. The only way i could get the cat material out was to use an oxy and just melt it out. It is made up of tightly packed "wavie" metal and it took me about 15 min with the oxy.
Then i welded it back together and checked if it would all fit back up.
Next it was time to give the mufflers a bit of lovin. I removed them from the bike and marked about 20mm back from the aluminum end caps. Again cutting with a hacksaw i cut the end cap off. Once that is done you will notice 3 holes on the engine side (1 right through and 2 blocked by a plate) and just the single hole in the end cap.
I then drilled into the plate behind the 2 holes that were blocked ( i used a pilot then about a 20mm drill).
Next was to open up the end cap. I used a hole saw of the correct size to remove the inner pipe, drilling from the outside in.
Next is to line up the ends with the mufflers and weld them back together.
Next i removed the aluminum end caps by drilling the tops off the pop rivets then hitting them through with a punch. So that you re-paint the mufflers as all your welds will rust. I will paint all the pipes from the cat up black (make sure it is with high temp paint or it will just melt off)
Now its time to fit it all back up and dry the paint as per instructions.
I haven't got mine painted up yet but will try and get some pics of it all done tomorrow.
Adam
