Me or the Bike? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jun 6th, 2008, 11:15 pm   #1 (permalink)
tunefx's Avatar
Me or the Bike?
In a rush I started up the bike and took off from work in the parking garage. The bike dies as I'm going down the ramp. I hit the starter (I'm still rolling) and it begins this oscillating idle at nearly 300-400 RPM. I give it a little gas and it dies. I hit the starter again and same idle problem. But this time I just stop. It sounds as if one cylinder is firing. I give it a bit of throttle and it dies. Hit the starter once more and she idles fine. I take off and no other problems since.
Has anyone had this happen before?
Did I just do everything a bit too quickly for the ECU to figure out throttle position, air, etc?
Normally I let her run about 30 seconds plus before taking off. Then again, I'm usually not late for dinner!
'08 HM 1100 S
tunefx is offline   Reply With Quote
Old Jun 7th, 2008, 12:25 am   #2 (permalink)
Lifetime Premium
Images: 59
Check that your battery cables are tight.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Old Jun 7th, 2008, 7:55 am   #3 (permalink)
My first hyper would idle very high around 3-4000, but was it got warmed up it went back to the proper 1200 and was fine after that. It never died like yours.
Now, the new one I gave the throttle a little twist up to 4000 and the thing died on my, but I am hoping its just a new bike thing and will play itself out. Oh, it did when the bike was completely warmed up as well.
Ferrell75002 is offline   Reply With Quote
Old Jun 7th, 2008, 8:29 am   #4 (permalink)
dratom's Avatar
My hyper won't idle when I first start it I have to hold the throttle open a touch until it warms. If I let it come down in RPM, it will die. I have never had a problem starting right back up though.
I remember when sex was safe and flying was dangerous.
dratom is offline   Reply With Quote
Old Jun 7th, 2008, 9:22 am   #5 (permalink)
Tightly Clenched...
Satansfist's Avatar
I had a WR 400 a while back and two things would happen when I started it: When starting from cold I'd use full choke but couldn't touch the throttle without it dying in the arse or I could start it with no choke at all and hold the throttle open a little bit.
Maybe your bike is like that, a little touchy on the fast idle circuit until it warms properly?
Satansfist is offline   Reply With Quote
Old Jun 7th, 2008, 9:55 am   #6 (permalink)
Lifetime Premium
Images: 59
None of the symptoms you guys are describing should be considered "normal".
Sounds like improper set-up to me. If your battery cables are tight, addition items to look at include:
1) TPS reset
2) Throttle Body Synch.,
3) Fuel trim adjustment if you have non-stock ECU; and
3) If you still have snatchy off- to on-throttle, then perhaps the idle speed screw needs to be cracked open a bit more (then repeat 1 & 2)
Bill
Bill
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Old Jun 7th, 2008, 3:59 pm   #7 (permalink)
Motard-Menace's Avatar
I agree with BillyD, this is not normal. With the advent of the computerized bikes we now ride there is something not properly tuned if you are having these issues. Its a matter of putting on a Dyno most likely and getting everything adjusted properly as long as you have already checked the little things like battery cable connections, fuses etc. I would take it in under warranty and have the dealer take a look.
MOTARD-MENACE
07 BMW F800S
Motard-Menace is online now   Reply With Quote
Old Jun 8th, 2008, 3:49 pm   #8 (permalink)
freezer16801's Avatar
that is why you have that nice warranty. Let them worry about it.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Help Me Decide Which Bike!! JimiThing Supersport 16 May 13th, 2008 9:17 pm
Ever try one of those fangled japanese bikes? tye1138 Ducati Motorcycle Chat 41 Dec 30th, 2007 10:01 pm
How many 2005 999R's are there? jackaus Superbikes 33 Jun 1st, 2007 6:57 pm
1098 or 999r johnhv Superbikes 64 Apr 18th, 2007 4:38 pm
