Jun 6th, 2008, 1:49 pm
air filter difference?
i'm putting the full termi system on next week, and wanted to see if anyone noticed a significant difference adding an k &n or bmc filter
Jun 6th, 2008, 6:20 pm
Search for "air box mod" and you'll find a ton of info. You want to improve the intake as well. I'm running BMC but will avoid the K&N vs BMC discussion.
You'll notice an improvement making the airbox and filter mods.
If your going to improve the "exhale" then give it a better "inhale".
Let her breathe!
'08 HM 1100 S
Jun 6th, 2008, 10:29 pm
No discussions
Let her breathe!
There will be no K&N vs BMC discussions, as K&N does not make a filter for the Hypermotard, but DNA does................Alex
Jun 6th, 2008, 10:34 pm
'nuff said. Thx Alex! Glad mine came with the BMC!!
'08 HM 1100 S
