Jun 5th, 2008, 4:08 pm
Leo Vince Cat Eliminator
Hee Haa!!! I just recieved my Leo Vince Cat Eliminator. Anyone here have any advice on what to do or not to do for installation? Should I use some kind of high heat sealant?
TIA.
ps
Forgot to mention that I have a Termi slip-on. Do I need to re-adjust anything? ECU?
Jun 5th, 2008, 4:15 pm
Eat, sleep, play!
Your throttle position sensor ( tps) needs to be reset and you should have your fuel trim adjusted. Take it to Nichols to have this done.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Jun 5th, 2008, 4:45 pm
Are you seriuos? Leo Vince told me that it's pretty much bolt-on and I shouldn't have to adjust anything. I am going to ask Desmoto Sport. Nichols is way too far from me.
Jun 5th, 2008, 7:25 pm
Eat, sleep, play!
Yes, if you are swapping the ECU you have to have the TPS reset. You can run the stock ECU and no reset is required but you run the risk of running a bit lean, especially if you are running non-stock mufflers and open airbox lid.
-2008 Hypermotard S
-2005 Buell XB9SX
-2005 CRF170R
Jun 5th, 2008, 8:51 pm
When you unbolt everything it will help alot if you loosen the front header pipe at the head. And trace the lambda sensor back and unplug it before you unbolt the cat. Other than that it was pretty straight forward.
Jun 5th, 2008, 9:04 pm
What is the power increase when you eliminate the cat and add a aftermarket slip on?
I am leaning toward the Zard slipons but i cant decide which one i want
2008 Hypermotard
1994 ZX9R Kawasaki gone and good riddance
Houston Texas
Jun 5th, 2008, 9:39 pm
Clamps
get some good clamps from PJ's
the ones ducati uses suck
W.F.O.
2000 748 Biposto-R.I.P.
2008 Hypermotard 1100
2008 KTM 250 SXF
Jun 5th, 2008, 10:16 pm
If any of you guys are fitting slip ons and/or cat eliminators and want a DP ECU let me know. FS: Peformance & Race ECUs in OZ.
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Jun 5th, 2008, 10:46 pm
Damn i wish i had a sweet stable of scooters like you have
2008 Hypermotard
Houston Texas
Jun 5th, 2008, 11:04 pm
1hp
The cat eliminator will add 1hp give or take, but more importantly
will make the bike run cooler, have better throttle response, and have a throatier exhaust note. The
full exhaust will add 3 to 4 HP, but when you do the airbox mod, BMC filter, or DNA, and a DP performance ECU you can expect an 8 to 10 HP total increase in power. Aloha Alex
