Dyno Sheet As Promised - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jun 3rd, 2008, 1:20 pm   #1 (permalink)
IPM
IPM's Avatar
Here it is: http://inlineperformancemag.com/inde...mus-dyno-sheet This is with the stock ecu, and no tuning whatsoever. stock filters. Only mod is the hexacone exhaust system.
http://InlinePerformanceMag.com
IPM is offline   Reply With Quote
Old Jun 3rd, 2008, 2:34 pm   #2 (permalink)
Question
stock ECU? eehh?? thats very good results, i am impressed! The termi wouldnt manage this increase in HP whatsoever. given thats all, but the termis, stock. Is it the full system? or just the slip ons Remus?
george_v is offline   Reply With Quote
Old Jun 3rd, 2008, 3:08 pm   #3 (permalink)
parkcrf's Avatar
Dynos seem to be so different from even run to run and day to day, temps..
Those results are impressive.
Here is mine to compare from a Superflow dyno (reads a bit less than dynojet).
I have a full 2-1-2 termi system, DNA filter, DP manifold ECU and custom tune with PC3
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Jun 3rd, 2008, 8:40 pm   #4 (permalink)
Images: 5
How's the air fuel ratio without any ECU changes? I'm curious how much that leans out the bike.
zekiel is offline   Reply With Quote
Old Jun 3rd, 2008, 9:16 pm   #5 (permalink)
MarksFriggin's Avatar
Same here. Very curious.
Old Jun 3rd, 2008, 11:56 pm   #6 (permalink)
not much use without a previous run unmodded to compare against.
Old Jun 4th, 2008, 1:40 am   #7 (permalink)
lelenb's Avatar
Images: 12
Good point Pedro.
plus oneness.
Lelen
Hyper S
Old Jun 4th, 2008, 2:10 am   #8 (permalink)
IPM
IPM's Avatar
Actually we were more surprised then you guys were! We have a sneaky suspicion that the dyno was over generous. I mean, it was off the Duc Truck. We believe that the results should be around the 80s.
Old Jun 4th, 2008, 4:09 pm   #9 (permalink)
Motard-Menace's Avatar
Is this with a full system or slip-ons. Hard to believe with no tuning, no filters etc. and only a slip-on you could pull 90 HP. But then looking at the TQ it shows 67 which seems low for the HP output. Curious for sure. Full Race Termi with tuning is putting out around 83-85 on most dyno's I've seen and then around 68-70 TQ numbers. Once you run it again keep us posted.
MOTARD-MENACE
07 BMW F800S
Motard-Menace is online now   Reply With Quote
TPO Beast Intakes Road Test & Dyno Results mattgregg Sport Classic 108 Oct 1st, 2009 1:00 pm
Dyno run of "Biggest Bang for the Buck" part II 08hyper HyperMotard 14 Jan 11th, 2008 11:23 pm
Hyper with Titanium pipes & Dyno sheet Shift-Tech HyperMotard 12 Dec 31st, 2007 12:29 pm
Dyno Mystery solved! mbohn Superbikes 15 Sep 9th, 2007 10:27 am
