May 30th, 2008, 5:41 am
Oil fitler leak
my oil filter has started to leak after 2100 miles of riding. this is the second oil filter i have put on this bike. the first went 3000 miles leak free. i put them on as tight as i can by hand, have always done oil filters this way and never had one leak. it does not seem to be loose at all. i even put a filter wrench on it and gave just a little turn and it still seems to be leaking. anyone ever run into this problem?
May 30th, 2008, 11:09 am
Maybe just a bad filter?
May 30th, 2008, 11:33 am
Lifetime Premium
WHAT oil filter brand are you using?
AMSOIL DEALER
06 MTS 750 SPS
08 HYPER BLACK
BOTH SERVICE & MODIFIED AT EASTSIDE MOTOSPORTS, BELLEVUE, WA, USA
May 30th, 2008, 12:06 pm
Manual states to tighten the filter down to 11 Nm or 8 ft lbs. This is WAY more than hand tight. I just changed my oil and when I was tightening the filter down, it seemed like a lot, but it's not leaking. My friend with a Moto-Guzzi Griso says his manual states 18 Nm. He did less one time and sure enough, it leaked.
Also, the drain plug is 42 Nm which equates to approx 31 ft lbs.
Torque it down my friend and you should be fine.
Cheers
May 30th, 2008, 12:47 pm
i'm using a ducati filter, i guess i'll do an oil change and torque it down this time. thanks.
May 30th, 2008, 1:52 pm
Eat, sleep, play!
Make sure you thoroughly clean the sealing oil filter sealing surface on the crankcase. A little left over gasket can cause leaks. Also, use a little oil on the gasket of the new filter. I hand tighten the new filter, no leaks. The original filter must have been installed by a gorilla as it was very tight.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
May 30th, 2008, 6:50 pm
Sometimes the WHOLE gasket can get left behind. Check the old filter to make sure the gasket came with it.
