No DP 44 tooth rear? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
SportbikeTrackGear
Old May 28th, 2008, 11:54 pm   #1 (permalink)
parkcrf's Avatar
I am considering going up 2 teeth on the rear sprocket when i do the 520 conversion. The DP rear sprockets are only listed as up to 43. Anyone know if there is a 44? Also, I assume a DID o-ring chain would be fine? instead of the DP chain which is a bit pricey
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old May 29th, 2008, 10:32 am   #2 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
You can order a 44T 520 Supersprox and 520 C/S sprocket and RK GB520GXW XWring chain from Drivesystems USA. You should get a premium quality chain. A standard DID O ring chain may not be strong enough.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old May 29th, 2008, 11:27 am   #3 (permalink)
ducatichick's Avatar
That is a beautiful sprocket!
Is that a Traxxion sock around the shock to protect it from gravel etc?
ducatichick is offline   Reply With Quote
Old May 29th, 2008, 2:57 pm   #4 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Yes, that's a Traxxion sock. Even with the hugger, gritty stuff still gets on the shock, especially when riding wet roads. Ohlins also has a neoprene shock sock available but they're scarce.
-2008 Hypermotard S
-2005 Buell XB9SX
-2005 CRF170R
Where to get 43 tooth rear sprocket (OEM)? NoCompromise Superbikes 8 May 11th, 2008 4:42 pm
43 or 44 tooth rear sprocket? RockingM Sport Touring 10 May 6th, 2008 7:16 am
42 tooth rear sprocket jtkayser1 Superbikes 6 Feb 8th, 2008 6:55 pm
41 tooth rear sprocket? overkill? XDELIRIOUS45X Supersport 29 Mar 21st, 2006 12:53 pm
