May 27th, 2008, 10:02 pm
1st gear is to short...
I think i need 1 tooth larger on the front sprocket
Does the Hyper come with a 14 tooth sprocket standard?
4th day riding this beast and i think 1 tooth larger is in line
I absolutely love this bike so far
2008 Hypermotard
1994 ZX9R Kawasaki gone and good riddance
Houston Texas
May 27th, 2008, 10:06 pm
I have tried a few second gear take-offs seems a little hard on the clutch but like you I have thought about going up one tooth on the counter shaft for better cruising on the slab. I am not sure how that will affect the switchback riding though so I have stayed stock for now.
May 27th, 2008, 10:17 pm
Stock is 15T
15T countershaft sprocket is stock on the Hyper,
You can't go bigger no room, drop thre rear to a 40T Aloha Alex
May 27th, 2008, 10:27 pm
I think thats the first post I have seen complaining that a Ducati anything 1st gear is too short. Usually its a complaint that they are too tall which I would side with. Ducati's 1st gear is notoriously taller then many other manufactures for whatever reason. I would guess some of it has to do with the tough Euro III emissions.
MOTARD-MENACE
07 BMW F800S
May 28th, 2008, 8:30 am
That's so newbies don't flip the bike backwards.
The 1100 motor is a torque monster!! A light flick of the throttle in first gear gets the front end right up. I have never had a bike that was so easy to wheelie!
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
May 28th, 2008, 8:51 am
Originally Posted by HYPERR
2nd & 3rd gear are better for wheelies, its easier to control.........
MOTARD-MENACE
07 BMW F800S
May 28th, 2008, 10:37 pm
'08 HM 1100 S
May 31st, 2008, 3:36 pm
It has to do with noise regs, and I agree the bike is overgeared. I'm going to go down a tooth on the front, OP, what kind of roads are you riding on?
