Handle Bar swap - Ducati.ms - The Ultimate Ducati Forum
Old May 26th, 2008, 3:56 am   #1 (permalink)
GHEZZI's Avatar
Handle Bar swap
Tried to mount a set of Pro Taper Reed/Henry bars the other day ($135 with 10%discount), but the extra height was too much for the brake line. I couldn't mount the master cylinder where required.
What bars have been fitted by you guys?
Old May 28th, 2008, 12:23 am   #2 (permalink)
infidel's Avatar
Ghezzi I had the same problem so i ran the brake line to the right of where the front fairing mounts to the triple clamp. Works fine
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
GT1000 Handle bar riser DMCTRUBY Sport Classic 19 Nov 24th, 2009 10:58 am
Will any of the aftermarket bar end mirrors with w/ stock grips/bar? SSR Sport Classic 6 Mar 28th, 2008 12:31 pm
Installation Question about Rizoma Bar Ends (506a) SSR Sport Classic 0 Mar 21st, 2008 6:26 pm
Does the bar end on the 06 Sport 1000 a NON-tapered solid mounted bar? SSR Sport Classic 2 Mar 18th, 2008 11:18 am
ECU swap on Sport 1000s with Termi slip ons tbone1 Sport Classic 6 Oct 25th, 2007 8:03 am
