May 23rd, 2008, 11:38 pm
Monster swingarm on a Hyper
I was looking at the Roland Sands hyper and it looks like the "custom" swingarm is off of a Monster.
Anyone know if a Monster swingarm will fit to a hyp? It would certainly allow for alot more rear tire width.
May 24th, 2008, 12:19 pm
Roland Sands Hypermotard
May 24th, 2008, 12:25 pm
Same bike, looks like two different swingarms to me. The first one looks like a stock Monster. Anyone know?
May 24th, 2008, 12:38 pm
"While the 19-inch front tire is two inches taller than the stockers, the most dramatic change is to the backside, where Ducati's 180/55 17 dimensions have been blown up taller and wider to 240/40 19. To accommodate the wider back rubber, the factory swingarm has been traded out for a thick RSD tubular trellis single-sided swinger"
May 24th, 2008, 4:58 pm
Damn that frame and swingarm color doesn't photograph very well does it? Looks like dog crap.
May 24th, 2008, 7:20 pm
If you go larger than a 190 you are going to need to change the front end attitude to compensate...otherwise your bike will want to go straight in turns.
Are you looking for a show bike or performance? From a handling perspective it sounds like a step backwards unless you are planning on changing up the front end chasis attitude as I said earlier.
Just an FYI :-)
May 24th, 2008, 9:32 pm
from my limited knowledge. two valve monsters and two valve ST's can use the same swing arm. multi's are a different width where they bolt to the engine cases. not sure about hypers, but they look the same as a multi
May 25th, 2008, 2:26 am
I'm going to get a chance to do some measurements Tues.
