Rev Limiter settings? - Ducati.ms - The Ultimate Ducati Forum
Old May 23rd, 2008, 11:20 pm   #1 (permalink)
LATEBRAKER's Avatar
I was doing a long third gear wheelie today on flat ground and let the front end drift a little low. I accelerated to bring it back up and was moving pretty fast. I was careful not to upshift at these high rpms (read loop it) when all of the sudden what felt like a rev limiter kicked in and sent my front end back to the ground. I didnt see my tach but I swear I wasnt turning more than 9k.
I own the standard HM with a Full Zard exhaust, Airbox mod and DP ECU.
Is this typical?
03 ZRX1200R
05 R1
00 XR650
97 CR500
02 S4
08 EX250
'00 R1150GS
LATEBRAKER is offline   Reply With Quote
Old May 27th, 2008, 8:58 pm   #2 (permalink)
Jeff4510's Avatar
yes, next time upshift, it won't loop, the powerband is very linear on these
08 HM S
05 CR500AF street project
05 CRF450X super moto/streeted
1985 Vespa ETS 125
1977 R100/7
Jeff4510 is offline   Reply With Quote
Old May 28th, 2008, 12:14 am   #3 (permalink)
AXE
AXE's Avatar
Christ, you had to be going 85 mph+ at that point. If it were me, I would back off and start the wheelie over again. When I have been pulling them in third gear I am somewhere between 70-80 mph and when I get above 80 mph I back off. Usually, I can feather the throttle and keep here going in that range and not hit the limiter.
Out!
2008 Ducati Hypermotard
Old May 28th, 2008, 5:56 am   #4 (permalink)
don't mean to high jack the thread, but, did you guys see superbikers on speed last night. jason britton was doing a photo shoot on a hyper and was riding a wheelie across a bridge, after a quarter mile the airbox was completley full of oil. it looked like it was just sucking it in and spiting it out the exhaust. he said this always happens to him on a stock ducati. any of you ever have this happen.
bfarm752 is offline   Reply With Quote
Old May 28th, 2008, 7:08 am   #5 (permalink)
lelenb's Avatar
Images: 12
The oil breather is at the back of the engine and the breather hose goes into the back of the air box so I could see how this would happen. Even if you move the breather to the front of the air box it could still blow oil on a long wheelie. My old TT500 would do this for the same reason.
Lelen
Hyper S
Old May 28th, 2008, 1:22 pm   #6 (permalink)
MarksFriggin's Avatar
That was phlewid's bike. He posted about that in this thread:
Long wheelies harmful?
Old May 28th, 2008, 2:20 pm   #7 (permalink)
JTL
JTL's Avatar
Would a "normal" crankcase breather fix that on the air cooled DS engine? (ala dirtbikes)
I saw Superbikers last nite too.
On my old S4 I replaced the factory setup w/ about a 10" hose connected to a small breather (after the oil debacle) and never looked back.
Evoluzione sells them very expensive, auto parts store sell them for practically nothing...
OH..h' HOWDY, i'm new.
Your Mom goes to college..
JTL is offline   Reply With Quote
Old May 28th, 2008, 3:36 pm   #8 (permalink)
LATEBRAKER's Avatar
Out!
Actually, I think I was cruising on balance point at about 55mph, then the front dived a litttle and I throttled up to 65 ish.
Upshifting on a wheelie at speed while turning 7k + rpm is a little too risky for me. I like to stay near balance point when shifting on wheelies. I probably should have let the front end down in the first place but, it did give me a chance to see where my limiter kicks in...
I am glad I posted this because I am now looking into the oil vent tube leak problem. I think someone suggested a typical vent tube filter/stone from a local autoparts store. Seems like a good fix to me.
03 ZRX1200R
05 R1
00 XR650
97 CR500
02 S4
08 EX250
'00 R1150GS
Advice to a New Owner Shazaam Hall of Wisdom 10 May 24th, 2012 3:52 pm
Advice to a New Owner Shazaam Hall of Wisdom 9 Jul 12th, 2010 12:51 am
999 DP ECU rev limiter (asym 1/2 system)? Cham32 Superbikes 10 Apr 14th, 2008 3:56 am
rev limiter yota HyperMotard 6 Mar 24th, 2008 6:57 pm
rev limiter Namor Superbikes 19 Jul 13th, 2007 10:09 pm
