Long wheelies harmful? - Ducati.ms - The Ultimate Ducati Forum
Old May 21st, 2008, 11:50 am   #1 (permalink)
Titbird's Avatar
My uncle says I shoud'nt make long wheelies because the cilinders won't get enough lubrication, and in the long run I will burn the valves. Seems BS to me. On every ride I make at least 5 wheelies, some of them quite long, what do you guys think, should I worry?
Titbird is offline   Reply With Quote
Old May 21st, 2008, 1:07 pm   #2 (permalink)
mig7410's Avatar
im more worried about what the leo's will do.
mig7410 is offline   Reply With Quote
Old May 21st, 2008, 2:25 pm   #3 (permalink)
johnchypermotard's Avatar
not sure where the oil pickup point is in the sump on the 1100 ds motor ... but i do know that ducati engineers went to a conical shaped oil sump on the testastreta motor, to avoid oil starvation on the superbikes when the motor gets angled while the front end is up in the air or the bike is leaned over for long periods through turns.
i suggest that you run a "full tank of fuel" length wheelie, and advise us if the motor gets eaten
Old May 21st, 2008, 7:03 pm   #4 (permalink)
phlewid's Avatar
The only problem I have encountered is 12'o clock wheelies... If you do them for longer than a few hundred feet, the crankcase breather will suck oil from the engine into the airbox and then dump it out of the drain tube.... which can result in an oiled rear tire... I know this because I let a certain stunt rider borrow my bike and saw it happen. Check out SuperBikes on sunday to see the results.
LINES
Phlewid Films
phlewid is offline   Reply With Quote
Old May 21st, 2008, 7:31 pm   #5 (permalink)
HYPERR's Avatar
I recall reading in a British bike magazine that Ducs do get oil starvation on the front cylinders from prolonged wheelies.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Old May 21st, 2008, 8:18 pm   #6 (permalink)
This is true, on some of my past Ducs and younger wheelie days the oil light would come on during long wheelies. I quit doing them many years ago so I am not sure if the DS motor has a different 'pump' system to resolve this or not.
I'd say...keep doing them! If you burn something up..then rebuild it even better!
Finnster is offline   Reply With Quote
Long Range Bike? Ara Multistrada 21 Oct 22nd, 2007 5:02 am
Any Long Distance Tall Riders??? davemc Sport Touring 20 Jan 18th, 2007 4:41 am
Pazzos clutch lever, short or long, air in lines kurtfriedrich Superbikes 11 Dec 13th, 2006 1:02 pm
HELP!!!! Removal of Long Oil Filter Needed???? jh225 Sport Touring 1 Apr 1st, 2006 5:05 pm
