May 20th, 2008, 1:46 pm
Bugs in the airbox
I finally installed my BMC filter last week and when I pulled my stock filter out a few dead bugs fell out of the filter. The way the airbox is designed anything loose on the filter can fall into the airbox when you remove the filter. I think it would be a good practice to use a small shop vac on the inside of the filter before you pull it out to suck out any small rocks or debris before they can fall in. I also greased the lip of the filter as I don't think the airbox design offers the best seal on top, especially with the hard BMC gasket material. I have the open lid installed btw.
Lelen
Hyper S
May 20th, 2008, 4:12 pm
Lifetime Premium
As my auto shop teacher always said about such things, "Cleanliness is next to Godliness." BTW, he as a hand-to-hand combat drill sargent for the Marine Corps, so us punk kids tended to listen to him.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
May 20th, 2008, 5:47 pm
any noticable difference with the new filter?
May 20th, 2008, 8:01 pm
Same problem
Lelen, I had the same problem, when I removed the air filter whatever loose
crap thats in there will fall into the airbox when you remove the filter,  I drilled
the bottom of the airbox with a modified 1 3/4 hole saw (teeth smoothed on
the OD of hole saw) for a perfect fit, and run a metal plate on top to hold
the filter down, now whatever debri that falls into the airfilter will fall straight thru.
As a side note when you drill out the bottom of the airbox, your bike will run
even better,  because of the increased air flow, Aloha Alex
May 20th, 2008, 11:23 pm
Yeah, this is a pretty shitty air box design. When I stuck my DNA in, I wasn't real confident that the seal was going to be that great. I thought abour cutting another piece of foam rubber to go around the top to ensure a positive seal between the outer edge of the filter and the filter cover. I didn't and I figure if it starts to use oil, I am gonna trade it.
In the FWIW column, one of the techs at Scottsdale Ducati said that he built a CBR race/street bike and the owner insisted on a BMC filter against the techs advice. He said he had the bike back in with only a few thousand miles and had to rebuild it. I guess the valves and pistons were pitted and pretty bad condition. He didn't recommend using the BMC and didn't seem to be a big fan of aftermarket filters. I trust what he says, but I haven't exactly removed it yet. I will probably check it at about 3K miles and see what it looks like.
Out!
2008 Ducati Hypermotard
May 21st, 2008, 12:07 am
Keep me posted
Out!
I installed a BMC filter at aprox 1500mi, I have 4500mi now, when I hit 7500mi
I will be doing MAJOR motor work, (new top end) so I will check out the
condition of the top-end, I will post what I find, I do feel that it will be fine
thou, as it looks like a K&N filter, and I use them on my Trucks and other bikes
and they work just fine, I do know that the paper filters do do a better job
at filtering out the super fine stuff, but thats why their more restrictive, so
its a trade off, as the K&N get dirty they will start to filter better, as the
trapped dirt becomes part of the filtering media, but what little particles that
do get by are so small that I don't believe they cause any harm. Just my 2
cents, Alex
May 21st, 2008, 12:16 am
cents, Alex
I pretty much agree, I ain't gonna sweat it. Getting a positive seal is higher on my list of priorities.
I run foam filters in the dirt and sand dunes and have never had a problem. I am now running an AEM non oil synthetic filter media filter in my Duramax and wife's Tahoe. Pull them out, wash em in water, dry them, and stick them back in. A company called Motoworks is supposedly making them for dirt bikes and quads. I hope they offer a line for street bikes.
Out!
May 21st, 2008, 1:58 am
Yes, I found more power from mid up. Not a huge increase, but noticeable. I had to turn in the air screws to make the bike idle after I installed it. I would not use this filter if you do not have a DP ECU of some kind, or your bike will be too lean.
It looks like there was some blow by on top of the stock filter as it had a few dust streaks on the edge. It could have happened when I removed the filter. It looks like Peter has the right idea with the Beast R air pods that he installed in his bike, but they are $300 for the pair. I am going to redesign the top of the airbox to make a better seal, maybe a neoprene gasket. I have some ideas.
Lelen
Hyper S
May 21st, 2008, 10:10 am
Eat, sleep, play!
I'm pretty happy with the Beast R setup. More torque and HP and a broader torque curve, its all good. It will really pay off later with the higher compression pistons, DP Cams, and some headwork. The stock airbox, even with the DP lid and the extra hole is just too small to keep up with the big gulps of air needed by the engine at mid to higher rpms.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
