Termi 2in2-Full System (not just slip-ons) - Ducati.ms - The Ultimate Ducati Forum
Old May 20th, 2008, 6:30 am   #1 (permalink)
Hello all, so on Friday I am installing the 2in2 full system, not just the slip ons. To begin with, the system costs a lot around 2500euro (do the conversion in dollars to see).
Somewhere in here i read that someone had a problem with the same system from licking pipes. Any help on this?
Second the system comes with 2 different ECUs, one with the slip-ons and another the racing one with the pipes. Which one should i mount on the bike?
Any opinion/direction from other HM owners with experience on this system would be graetly appreciated.
p.s i ll post pics once done
George
george_v is offline   Reply With Quote
Old May 20th, 2008, 7:35 am   #2 (permalink)
Official Sponsor
desmoworks's Avatar
Definitely use the ECU that comes with the collectors - it is designed to be used in conjunction with the Termignoni slip-ons you are using. You should be able to sell the ECU that comes with the slip-ons.
Good luck!
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is offline   Reply With Quote
Old May 21st, 2008, 7:05 am   #3 (permalink)
Thumbs up
thanks a lot.
Old May 21st, 2008, 8:20 am   #4 (permalink)
xrsupermoto's Avatar
I'm running a custom version of this pipe. It works very well, dynoed 10 hp more than just the slip-on. I'm running the cam ECU, but the race ECU will work better. You will have to run the ECU that came with the headers, due to removal of the exhaust backpressure valve. The slip-on ecu will set a check engine light with the valve unpluged. You could sell the slip-on ECU to someone who purchased a different aftermarket pipe.
2008 Ducati Hypermotard
2005 CRF450X supermoto race bike
2001 XR650R supermoto street bike
2005 BBR 125 mini supermoto
xrsupermoto is offline   Reply With Quote
Full system ECU vs Stock rubyvrooom HyperMotard 13 Aug 29th, 2007 10:27 am
Termi asymmetrical to full system conversion black749s Superbikes 8 Apr 5th, 2006 5:56 pm
Does the termi half system included with a 999s fit a base 999 (03/04) UndergroundLare Superbikes 10 Mar 30th, 2006 7:36 pm
