DP termi ECU - Ducati.ms - The Ultimate Ducati Forum
Old May 18th, 2008, 11:35 pm   #1 (permalink)
freezer16801's Avatar
DP termi ECU
I should get my DP termi ECU next week sometime. What are the differences between this ECU and the stocker? I am just wondering if I'd be better off with the stock one and a Power Commander or the DP ECU. It seems to me that the DP ECU isn't too flexible with future upgrades. I tried searching but couldn't find much info. on why this ECU comes with the exhaust purchase.
Old May 18th, 2008, 11:49 pm   #2 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Which DP ECU are you getting? There are several. The DP ECUs that come with the cam kit and the Termi 2-1 exhaust both run in the open loop mode with the deletion of the 02 sensor. The cam kit ECU provides around 18% more fuel than the stock ECU while the 2-1 Termi ECU provides about 10% more fuel over stock.
The stock ECU runs in both closed loop and open loop. If you run the PC with the stock ECU you will only be able to adjust fueling above a certain rpm/throttle opening, as it can't override the closed loop mode of the stock ECU.
Another alternative to the power commander you might want to consider is the Rapidbike 3 module. Its available with an 02 emulator that allows the RB unit to adjust fueling throughout the entire rpm/throttle opening range using the stock ECU. Either the RB3 or PCIII will work with the cam kit or 2-1 ECU without the 02 emulator. Hope this isn't too confusing.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old May 19th, 2008, 9:18 pm   #3 (permalink)
no, it clarifies things pretty well. I have the 2-1 ECU on the way this week. So, it looks like this is a good start.
Old Jul 9th, 2008, 2:57 pm   #4 (permalink)
does the ECU that comes with the slip-on's run open loop?
Old Jul 9th, 2008, 3:43 pm   #5 (permalink)
Leo Vince stock ECU
I have the leo vince pipes and have the kat eliminator in the garage but don't want to put it on until I get either a dp ecu or something else. What should I do?
keatonm10 is offline   Reply With Quote
Old Jul 9th, 2008, 4:01 pm   #6 (permalink)
parkcrf's Avatar
I have a new in box DP cams ECU I'm thinking of selling. PM if interested
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Jul 9th, 2008, 5:14 pm   #7 (permalink)
Enigma's Avatar
im glad dukepilot knows his stuff because everytime he posts i learn something new, im actually thinking of selling my cams if they ever come in instead of spending money on that and HC pistons
Enigma is offline   Reply With Quote
Old Jul 10th, 2008, 1:53 pm   #8 (permalink)
I'm not really familiar with what I need or what I can use. I Also read on this forum of members with the Leo pipes and Kat eliminator installed with the stock ecu. This is my first Duc and I don't want it to run lean but I really want to put on the kat eliminator asap.
Old Jul 10th, 2008, 2:33 pm   #9 (permalink)
GMP
My bike has 500 miles on it. I just did the LV cat eliminator, DP airbox lid, disabled flapper, and geared down to 14/42. Bike runs good, appears to be no leaner than stock and actually seems smoother. I guess the stock closed loop can compensate for these minor changes but noway of knowing for sure without a gas analyzer. Slip ons me be pushing it but I wouldn't worry about the cat eliminator.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Jul 10th, 2008, 6:29 pm   #10 (permalink)
I too would like to know if the slip-on ecu is an open loop.
Ireek is offline   Reply With Quote
Termi ECU ducatisuperbike Superbikes 5 May 21st, 2008 10:18 pm
Termi ECU change to US setting? ElDiablo Superbikes 6 Apr 9th, 2008 1:54 pm
15M ecu - help! dirkwrong Ducati Motorcycle Chat 7 Mar 28th, 2008 7:46 am
