Way to lean! - Ducati.ms - The Ultimate Ducati Forum
Old May 17th, 2008, 12:06 am   #1 (permalink)
Images: 2
Way to lean!
IŽll took my HM to my local Ducati dealer for a run in the Dyno. IŽll wanted to know if the bike have a decent fuelcurve and the effect with the Db killers installed. The result was rather interesting when my bike is overly lean and a staggering 7,7 hp stronger with the Db killer installed. I have Bursi frontpipes, Leovince silencers, Dp airboxlid, airbox mod with a 41mm hole in te bottom of the airbox, camkit with Race ECU. The result was 92,57 hp and 97,57 Nm on top. IŽll have a nasty dip in torqe between 4700 to 5500 rpm. Ill think I have to get a Powercommander to solve this when the bike runs lean even with the killer in place. Se the graph here: http://www.olssonsgarage.se/Hypermotard.htm
Olzone is offline   Reply With Quote
Old May 17th, 2008, 12:55 am   #2 (permalink)
08hyper's Avatar
Jonas, COOL video! where did you get the Bursi head/mid pipes that fit on the LV
slipons? do they have a larger OD pipe diameter than the stock pipes? also
the DP ECU that you were running, is it the ECU that came with the cams or
is it the ECU that comes with the DP Termi race pipe, Thanks Alex
Old May 17th, 2008, 12:56 am   #3 (permalink)
AXE
AXE's Avatar
Cool! Nice numbers, it looks like it is hitting hard up top. I know that some of the guys in Cali with the LV cans were also seeing a little better numbers with the dB killers installed. Interesting!
Out!
2008 Ducati Hypermotard
Old May 17th, 2008, 9:09 am   #4 (permalink)
Koop's Avatar
I wish your graph included Air:Fuel Ratio. Definitely could use a Power Commander and some tuning - the torque curve looks peaky. Nice bike and web page - couldn't read a thing but I like the photos (kinda like a Playboy magazine).
'08 Ducati 848 Superbike - Full Termi
'07 MV Agusta Brutale 910R - Gone
'08 BMW R1200RT...his
'04 Moto Guzzi Breva 750...hers
http://g2motoracing.com/
Koop is offline   Reply With Quote
Old May 17th, 2008, 10:22 am   #5 (permalink)
Images: 2
Smile
Well I bought the Bursi pipe on http://stores.ebay.com/BURSI-EVOLUTION.
The front pipes are 5 mm larger than original, but the connection with the rearpart have the same size as on the originalbike. The cat is gone and you can use it with a closed loop ECU with lambda sensor as well. I have the lambda hole plugged when I have the camkit Race ECU installed.. Koop! Swedish can be a bit tricky!
Old May 17th, 2008, 10:29 pm   #6 (permalink)
08hyper's Avatar
Red face Need help!!
I went to Ebay on your link, and did not find the Bursi / LV midpipe for the Hypermotard, I even went on their offical website and did not find it.
Could you contact them for a part# and find out how much they
will be in U.S. currency? Thanks Alex
Old May 18th, 2008, 12:05 am   #7 (permalink)
Images: 2
Contact them and refer to my site. They called it Bursi evolution decatilazzitore marmitta. The price for this was in the same range as for LV decat pipe ca 3000 sek or 485$. You are a lot better in English/American than I am so I donŽt think they will have any problem to understand what you want.
Old May 19th, 2008, 12:08 am   #8 (permalink)
08hyper's Avatar
Question Can't find the phone number
Could you give me the companies phone number and the part number
for your Bursi mid pipes? Thank you Alex
Old May 26th, 2008, 3:50 pm   #9 (permalink)
Images: 2
IŽll have my site translated.....
'92 750 Vertical cylinder running lean PETE Supersport 9 May 7th, 2008 1:45 am
G-forces and lean angles (for you science nerds) TheVanillaThrilla Superbikes 5 Feb 29th, 2008 9:23 pm
FYI 695 Monster Lean Condition 07695DARK Monster 9 Feb 23rd, 2008 3:14 am
Just installed FBF chip and it's running lean.....now what?? Kernel_Panic Sport Touring 6 Feb 7th, 2008 4:24 pm
Termignoni 1/2 system, too lean? help... SBKPILOT Superbikes 18 Jan 13th, 2008 3:18 am
