Question about CRG or Pazzo levers... - Ducati.ms - The Ultimate Ducati Forum
Old May 15th, 2008, 9:37 am   #1 (permalink)
Do both of these require that you use a short lever with the stock handguards? Will their standard size levers fit?
Old May 15th, 2008, 2:29 pm   #2 (permalink)
Brainfry's Avatar
Can't speak for CRG, but Pazzo's must be short to fit with the stock handguards. I found out the hard way.
B
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Brainfry is offline   Reply With Quote
Old May 18th, 2008, 1:55 am   #3 (permalink)
I just installed the Short CRGs after some minor modification to the brake lever with a dremel tool.
I removed my hang guards long ago, so it was a non-issue. During my quest for the right beta before I started grinding away at a freshly bought pair of levers, a few techs mentioned that you had to modify the guards, (and modify the brake lever)
Aside for the BS of install, the CRGs are great. I love them. A lot. No seriously. I'd screw them if I could.
gravityslave is offline   Reply With Quote
Old May 18th, 2008, 11:17 am   #4 (permalink)
Lifetime Premium
Images: 59
If you run a shorty clutch lever, you should also consider changing the slave cylinder to lessen lever pull. I ran my shorty Pazzo with the stock slave cylinder for a long time and it was fine, but I threw in an Evolution slave cylinder on another parts order just for grins, and the resulting decrease in lever pull was welcome. Worth it IMHO even though I hate bleeding hydrallic systems of all types.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Old May 19th, 2008, 5:46 pm   #5 (permalink)
Fresno's Avatar
Okay, so the CRGs need to modified. In what way?
Also, do the Pazzos fit without mods?
Sound off if ya got a pair (levers, that is).
Fresno is offline   Reply With Quote
Old May 19th, 2008, 6:23 pm   #6 (permalink)
Brainfry's Avatar
No mods to the Pazzo's... but to the OEM lever.
See below,
B
Pazzo Pain
'05 BMW K1200LT
'10 BMW S1000RR
CRG Levers for HYM Nessy HyperMotard 22 Apr 19th, 2012 9:27 am
Pix of DP Handguards, Mirrors, & CRG Levers socalrob HyperMotard 5 Apr 29th, 2008 12:03 pm
Installed CRG Levers. Question about adjustment/freeplay Craw Monster 0 Aug 30th, 2007 11:14 am
Pazzo levers install and clutch bleeding help CrazyINP Superbikes 13 Aug 17th, 2007 10:38 pm
Pazzo Levers and clutch slipping johnVallejo Superbikes 17 Apr 9th, 2007 10:46 am
