Set you suspension sag and adjust the compression and rebound settings. You will eliminate the twitchy front end. Not that many people seem to think the DP stabilizer is good. There are some others out there including a Scotts that start around $500+.
Do a search on suspension settings and stabilizers and you can read up.
Out!
2008 Ducati Hypermotard
