Flapper valve and check engine light - Ducati.ms - The Ultimate Ducati Forum
Old May 14th, 2008, 7:19 pm   #1 (permalink)
thoroughly addicted
I'd like to try running with the flapper valve disabled to see what improvement that would make with no other changes. The easy way to do it would be to unplug the server wiring and rotate the servo pulley to the open position. That would of course trip the check engine light.
To turn the light back off, would the dealer have to reset it or will it reset itself when I plug the connector back in? Just wondering. I just wanted to do a quick easy experiment...
Debby
In the garage:
07 GT1000, gray
Previously in the garage:
65 250 Scrambler
02 998 Mono
07 Hyper S
97 900 SS/CR
67 250 Scrambler
debby is offline   Reply With Quote
Old May 14th, 2008, 10:56 pm   #2 (permalink)
I did just what you are thinking. It made a BIG difference in more power. I took the bike back to the dealer and they ran the bike on the dyno with and without the flapper connected. The difference was 9 rear wheel horse power. This all started after they installed the dual termi's 8 months ago. A new ecu is on the way.
Bob
bbenn75820 is offline   Reply With Quote
Old May 14th, 2008, 11:02 pm   #3 (permalink)
Banned
Images: 13
Wink Flapper
I removed the valve and the cable , but let the wires to the servo motor attached , no light this way...
The race exhaust ecu and the one with the cams does away with this system , so does the mid race pipe system for the dual termi's
Gee-Bee
GEE-BEE is offline   Reply With Quote
Old May 15th, 2008, 6:56 am   #4 (permalink)
Gee-Bee
Is there a post where I can see that with pictures?
I donīt really know what parts are the servor, the flapper or the valve
hyperduck is offline   Reply With Quote
Old May 15th, 2008, 8:31 am   #5 (permalink)
Banned
Images: 13
Red face ?
Servo is the electric ,motor that controls the cables
Flapper is the valve , there is a bearing on one end
I took a hack saw and cut the bearing clean at the pipe , unsrewed the flapper on the shaft , removed
Took the pipe to a muffler shop and had it patched ( two hole's ) and then sent it out with the LV Cat pipe for ceramic coating...
Need more help your welcome to call..
Gee-Bee
Old May 16th, 2008, 9:01 am   #6 (permalink)
thoroughly addicted
That's all good, but it doesn't answer my question:
If I unplug the servo, go for a test ride, then shut off and plug the servo back in, will the check engine light still be on the next time I start the engine? Or will it reset? With the standard ECU.
Debby
In the garage:
07 GT1000, gray
65 250 Scrambler
02 998 Mono
07 Hyper S
97 900 SS/CR
67 250 Scrambler
Old May 16th, 2008, 9:27 am   #7 (permalink)
Banned
Images: 13
Wink Cel
It will probly turn back on , Mine did that's why I left it attached
The Ecu looks for that connection ...
Options:
DP Mid Pipe, includes Ecu
Dp Cam Kit with Dp Full Race Exhaust
DP Race Exhaust System
DP Race Exhaust Ecu
Cam lobe position for valve clearance check WAP Superbikes 13 Nov 2nd, 2008 6:29 am
valve collets in the engine james777 HyperMotard 4 Feb 20th, 2008 1:33 pm
Check engine light is coming on my gt1000 3stephenD Sport Classic 1 Oct 31st, 2007 11:09 pm
How many hours for valve adjustment & belt check only? 3stephenD Sport Classic 4 Jul 18th, 2007 9:10 pm
First Scheduled Service Question Tylerman Sport Touring 9 Jan 4th, 2007 7:27 pm
