Control set-up - Ducati.ms - The Ultimate Ducati Forum
Old May 14th, 2008, 12:10 am   #1 (permalink)
LATEBRAKER's Avatar
Control set-up
I was surprised to find I could not adjust the Clutch and Fr Brake lever to my liking. Typically I like the handlebars just a degree or two back from center alignment with the forks, and the levers pointing a bit down.
I went to adjust my levers today and found they are factory set with a stay somehow intergrated in the bar clamp(s).
I didn't have time to take them apart today to find the problem but I definetly will. Maybe it's the off-roader in me but, does this bother anyone else here?
03 ZRX1200R
05 R1
00 XR650
97 CR500
02 S4
08 EX250
'00 R1150GS
LATEBRAKER is offline   Reply With Quote
Old May 14th, 2008, 12:22 am   #2 (permalink)
AXE
AXE's Avatar
Bars have a hole in them and the mounts have a peg to hold them in place. You should be able to grind the peg down and position them any way you want.
Out!
2008 Ducati Hypermotard
Old May 14th, 2008, 12:26 am   #3 (permalink)
+1 Axe...
It bothered a lot of us! That's why most of us have gotten rid of the locating pins and adjusted our bars and levers they way we like them...
Old May 14th, 2008, 2:25 am   #4 (permalink)
lelenb's Avatar
Images: 12
My controls are pretty far forward, I had to bend the reservoir brackets to level them out. If you remove the locating pins on the other controls you will need to wrap the bar with a piece of electrical tape because there is very little clamping force with the stock plastic housing. The lever perches have sufficient clamping force so they will be fine.
Lelen
Hyper S
Old May 14th, 2008, 9:58 am   #5 (permalink)
Goodwood's Avatar
It's an easy mod. Most people feel the locking pin was put there for ease of installation at the factory--worker grabs levers, puts against pin, no measuring or adjusting.
AZ SCOTT I think was the first to suggest back in the day...loosen levers and switch housing, slide them over slightly so you can see the pins, grab pliers/vice grip and pull pin out, NO grinding needed! Sit on bike and position levers to your liking, tighten down and go!
Goodwood is offline   Reply With Quote
Old May 14th, 2008, 8:47 pm   #6 (permalink)
totnac's Avatar
this is the first thing i did when i brought home my bike
Anthony
totnac is offline   Reply With Quote
Old May 14th, 2008, 9:36 pm   #7 (permalink)
LATEBRAKER's Avatar
Great,
Thanks for the beta!
Oddly enough, My '73 RD350 had a similar locating pin set up, waaaay back when...
03 ZRX1200R
05 R1
00 XR650
97 CR500
02 S4
08 EX250
'00 R1150GS
Thinking about getting a full set graphics... NickT916 Superbikes 5 Mar 1st, 2008 2:47 pm
Traction Control 1098 ??? How does this work? rapter Superbikes 20 Nov 7th, 2007 11:55 am
Fast Idle Control Only? stover Ducati Motorcycle Chat 9 Jan 23rd, 2007 1:11 pm
06 Production Traction Control? (very minor race spoilers) CKvBP Superbikes 4 Aug 21st, 2006 3:50 pm
