you should not have any air leak from the cat eliminator to riser pipe connection.
i have not seen the termi/dp riser and/or the stock riser installed with the leo vince cat eliminator, so i cannot advise if this is a fitment issue, or if you simply need to use a little header silicon between the pipes at the connection to more fully seal.
bottom line: you should not have exhaust leaking from the pipe connections.
