For Leo Vince owners ONLY!!! - Ducati.ms - The Ultimate Ducati Forum
Old May 5th, 2008, 9:06 pm   #1 (permalink)
08hyper's Avatar
Talking For Leo Vince owners ONLY!!!
I have a lot of connections in the aftermarket industry, and was thinking
of having a stepped exhaust manifold built for my Leo Vince slip ons, I will be
using the Termi RACE stepped manifold as a guide, and have it fit into the
LV's (no reason to reinvent the wheel) The stepped header design should favor
the power in the upper ranges, and work well with the DP cams, I will try
and have the header pipes tuck in tighter, for more cornering ground
clearance, as on Track day I ground my stock front header pipe.
Want I need to know if there are Leo Vince owners that would be interested
in this manifold set-up, I do not have a price yet, as it will depend on how
many I can order, but will cost far less than the Termi mid manifold for sure.
So please post up if interested, as I need an approx count. Thanks Alex
Old May 5th, 2008, 9:19 pm   #2 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
I'm interested but I need to know the price before I can commit. I assume that they will be made of stainless steel. You might to consider routing the pipe for the front cylinder under the engine for cornering clearance and for better access to the oil screen. The Staintune headers for the multistrada are routed this way.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old May 5th, 2008, 9:28 pm   #3 (permalink)
I am in
Scotty
08 hypermotard S
08YZF250F SM
06WR450F SM
scottysspeedshop is offline   Reply With Quote
Old May 5th, 2008, 10:30 pm   #4 (permalink)
08hyper's Avatar
Same as Termi.....
Peter, the pipe routing will be just about the same as the Termi race pipe,
I cannot run the pipe under the engine as some of us have skid plates, or will
have, so it must fit with this option, if you have to take off the header pipe
for the oil screen access with the Termi pipe, (I don't know) then you'll have
to do the same for this pipe. Alex
PS: yes they will be SS, but the prototype will be mild steel
Old May 5th, 2008, 10:36 pm   #5 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Alex, I'm still interested!
-2008 Hypermotard S
-2005 Buell XB9SX
-2005 CRF170R
Old May 5th, 2008, 10:48 pm   #6 (permalink)
08hyper's Avatar
Wink Same as yours......
Peter, the manifold should really work well with your set-up, it will be much like mine,
I plan to go 1123 Pistal big bore HC pistons, porting, maybe larger valves,
and the installation of my DP performance cams. I going to wait on the TPO
air intake set-up until I do a dyno run, to see what numbers she pulls, if I can
get in the 105HP range, I'll keep the airbox. Alex
Old May 5th, 2008, 11:44 pm   #7 (permalink)
johnchypermotard's Avatar
+1
Old May 6th, 2008, 12:19 am   #8 (permalink)
Moderator
cassos's Avatar
+1
Looking at how Peter's exhaust manifold is so shinny, I was starting to think of cleaning mine, now replacing it is a better idea
cassos is offline   Reply With Quote
Old May 6th, 2008, 12:21 am   #9 (permalink)
hyprduc's Avatar
I guess I have to just to keep up!
hyprduc is offline   Reply With Quote
Old May 6th, 2008, 12:26 am   #10 (permalink)
Navigator's Avatar
definately interested!!! I still have the stock header and cat since I wasn't able to get the LV midpipe as it was on back order when I got the slip-ons.
08 Hypermotard
05 CRF-450X Supermoto (CA plated)
01 YZ-426F
Navigator is offline   Reply With Quote
Attention Leo Vince owners... Brainfry HyperMotard 3 Mar 25th, 2008 2:07 pm
Keith Code to host Superbike School for Ducati Owners Group John Ducati Motorcycle Chat 6 Apr 29th, 2007 8:17 pm
Anyone used Competition Werkes & Leo Vince exhaust? 2fasst Superbikes 3 Jan 8th, 2007 11:49 am
Ducati Superbike Owners Unite! Dark_Daddy Superbikes 15 Nov 13th, 2006 11:56 am
