finally installed the J Murph special flat track bars by Vortex. I will most likely cut these down 2 or 3 inches but wanted to try them stock. 34" wide! A little higher than stock and a bit more sweep. Rode for about an hour today and I liked them.
While I was at it I had a billet alum throttle that rotates on a ball bearing in the end of the bar that I had taken off my old YZ 4 stroke mxer. Strangely enough the tube fit perfectly in the hyper throttle housing and was perfect for the stock cables.
