new hyper owner - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old May 2nd, 2008, 6:56 am   #1 (permalink)
new hyper owner
ok guys i pick my bike up in about a week .........the only mods i am gettin is the 2 into 1 system and am leaving the rest stock ............any tips for the new owner ..........and small probs i should look out for or anything i should keep an eye out for and yes this is my first ducati
cheers
kongman27 is offline   Reply With Quote
Old May 2nd, 2008, 10:40 am   #2 (permalink)
sloduck's Avatar
Congrats!!! I am going to pick up mine today. Can't wait.
sloduck is offline   Reply With Quote
Old May 2nd, 2008, 10:59 am   #3 (permalink)
shat's Avatar
Yes. Here's one from another Hyperactive: Watch out if you wear pants/jeans with slightly loose cuffs. It has been reported that on several occassions, when coming to a stop and attempting to plant the left foot, the rider's cuff caught on the hydraulic clutch bleeder valve and caused an embarrasing and costly topple at the red light. Not a pretty picture, to be sure. S**T HAPPENS
shat is offline   Reply With Quote
Old May 2nd, 2008, 11:07 am   #4 (permalink)
HyperMotard21's Avatar
Images: 61
If you weigh in close to my weight, you would need quite an adjustment to the front suspension. I'm 66kg and found the front way to twitchy. Heavier riders reported this too so you get my drift.
Get it done (static sag) before your first ride out.
Remove the rubber gasket from your clutch cover (retain the washers) to reveal a gap. This will make your clutch plates last longer (heat venting) and initial first hours of rides produces the most dust rubbing of new clutch plates.
It also makes it sounding more like a dry clutch bike
A HyperTard on a HyperMotard
HyperMotard21 is offline   Reply With Quote
Old May 2nd, 2008, 11:11 am   #5 (permalink)
Werloc's Avatar
Images: 6
That almost happened to me, but I cought it in time. I lifted my foot then planted. I had my wife on the back at the time. By the time I got home I forgot about it. Reading this just reminded me...
Werloc is offline   Reply With Quote
Old May 2nd, 2008, 11:16 am   #6 (permalink)
Werloc's Avatar
Images: 6
Can you post pictures of this done? I'm thinking about doing something like that to mine. I have plastic washers that are about the same thinkness of the rubber gasket.
Old May 2nd, 2008, 11:34 am   #7 (permalink)
sloduck's Avatar
Or just install one of these. $75.00 plus shipping. I have 1 blue and 1 silver.
Old May 2nd, 2008, 12:46 pm   #8 (permalink)
Images: 61
There are 2 screws that need not be removed when removing the clutch cover (approx 11 oclock and 8 o'clock) . Then remove the rest of the screws. Remove the rubber gasket reinsert the screws and before mounting, insert the metal washer, it stays between the clutch cover and the main housing. This will leave a few mm gap.
This will cool better and you no longer need to open it up at service intervals for its required blow job That;s when you see a huge cloud of clutch dust trapped with sealed clutch covers
Can't provide a pic as today my vented covers finally arrived
Old May 2nd, 2008, 7:36 pm   #9 (permalink)
75 dollars is a great price. You still have one left? Are they aluminium?
Life without my motorcycle is no life at all.
Speednut is offline   Reply With Quote
Old May 3rd, 2008, 6:17 pm   #10 (permalink)
sloduck's Avatar
They CNC machined and yes they are aluminum and anodized. I have gold, silver and blue. Sold the black one.
Multi vrs Hyper bromike666 Multistrada 31 May 28th, 2008 2:11 pm
Potential new Hyper owner GMP HyperMotard 6 Mar 28th, 2008 12:15 pm
New Hyper Owner Questions Rozebud HyperMotard 1 Mar 10th, 2008 10:06 pm
New Hyper S Owner MikeS HyperMotard 2 Jan 28th, 2008 9:53 am
Sacramento Hyper owner on HWY 50 e.b. DT996 HyperMotard 3 Sep 8th, 2007 7:00 pm
